Starts...then shuts off... - Ford Truck Enthusiasts Forums
Old 11-12-2010, 04:46 PM
AndeyHall's Avatar
AndeyHall AndeyHall is offline
AndeyHall is starting off with a positive reputation.
Well, after having my truck reflashed at Ford yesterday morning (although I'm not really sure this problem is because of that, maybe just a coincidence), I noticed that at idle rpms, it will studdor every once in a while like it's losing either fuel or oil pressure, and if you let it do it long enough without pressing the gas it would just shut off. Then this morning, I changed the fuel filters getting ready to make a trip up to NC, and after changing the fuel filters it would stay cranked just a few seconds and then just shut off almost right away. Yes, I primed it a TON before I tried cranking it. Again, the only way I found that I could keep it from shutting off was to hold the brake, start it and throw it in gear really fast, then hit the gas as soon as it was in gear. Any ideas? ICP and connector was just replaced like 4 months ago. Didn't think to check for codes this morning but it wasn't throwing any codes yesterday while it was doing it.
Old 11-14-2010, 04:41 PM
AndeyHall's Avatar
Bump, nothing?
Old 11-14-2010, 05:19 PM
solaratomic's Avatar
solaratomic solaratomic is offline
solaratomic is starting off with a positive reputation.
Have you checked the EGR valve?
Old 11-14-2010, 05:22 PM
AndeyHall's Avatar
Quote:
I'm going to as soon as I get home. But if I have an EGR delete, what exactly could it be doing and what exactly would I be looking for?
Old 11-14-2010, 05:32 PM
Oh with a delete it shouldn't be a problem. You need a sig. Do you have any way to scan for codes or get live data? What year? Miles? etc?
Old 11-14-2010, 05:39 PM
AndeyHall's Avatar
??I do have a signature??? Not sure if it has anything to do with me posting from my blackberry. But it's an 03 with 170k miles, EGR delete and straight puped. I have an insight I can chec for codes with, but I'm almost positive it won't show up anything. Because it wasn't yesterday when I scanned it after it was doing this.
Old 11-14-2010, 05:45 PM
Yeah I can't see your sig, not sure of reason. I would be interested see what your ICP on IPR readings are.
Old 11-14-2010, 05:47 PM
tex25025's Avatar
tex25025 tex25025 is offline
tex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud of
Quote:
That doesn't mean that you aren't having codes in the system. You really need something a little more involved then the Insight for code scanning.
Also, your siggy isn't showing up. It shouldn't have anything to do with the BlackBerry as it's all on your online profile and you obviously had to at one point sign in, so that should have posted it on your post unless you "unchecked" the box by "show signature".
Check for eletrical issues first and then move onto the mechanical ones.
Old 11-14-2010, 10:13 PM
AndeyHall's Avatar
I'm going to check on the sig thing as soon as I hit post.
But I've been in NC all weekend and just got home a little earlier today so I haven't hadn't had time to look at anything over the weekend. Anyways, when I got home today, I figured I'd try and crank it up and see what it did. It started up fine, and I let it idle for 5 minutes straight expecting it to start acting up at any minute. It never did. I drove it around the neighborhood a few times, then let it idle for 5 more minutes and still nothing. Drove it to work to pick up my new HID's that came FedEx while I was gone...never had any issues. So I don't know what the deal was Friday. Not sure if it was just a fluke thing or what.
But tex, the only reason I was suspecting mechanical issues was because it only had a partial issue before the new fuel filters, then after the new fuel filters it wouldn't stay cranked for more than 10 seconds. Just seemed like it had to be a mechanical issue. But I don't guess it really matters now unless it starts acting up again. Guess we'll see though.
Old 11-14-2010, 10:22 PM
AndeyHall's Avatar
It must have something to do with posting mobile because my last post was from a computer and it shows my sig but the others were posted from the blackberry and they don't show it.
Runs for a few seconds and stalls ken taromino 6.0L Power Stroke Diesel 2 04-29-2016 07:54 PM
Stalling after basic maintenance ultraclyde 1994.5 - 1997 7.3L Power Stroke Diesel 11 01-12-2016 09:30 AM
out of ideas 6.0 crank no start. joe.d 6.0L Power Stroke Diesel 44 08-14-2011 06:56 PM
Truck shut off while driving... Fuel Pump? Bino2 1994.5 - 1997 7.3L Power Stroke Diesel 14 10-08-2009 05:33 AM
What is a code 28? dazzleaj Ranger & B-Series 4 05-22-2007 05:50 PM
Tags
1999, 46, 54, changed, f150, ford, lossing, navigator, oil, pickup, powerstroke, rpms, shuts, shutting, starts, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
