86 Ford F250 Vacuum diagram
Does anyone have a vacuum diagram for a 1986 Ford F250 with a 460 that pertains more specifically to the climate control system set up? It has a/c and standard heat package. I am needing to chase down vacuum lines and make sure everything is hooked up to the right spots. The one under the hood on the radiator support I think pertains mostly to the smog control stuff that is no longer on my truck. Thank you to anyone who can help
I dont believe it is the california truck, in fact I am near positive, it was originally sold here in Oklahoma at a local dealership, it came stock with a Holley 4 barrel and it did have the A.I.R equipment on it, but that has all since changed. It is factory A/C though. It is a XLT lariat edition. If you have one I would really appreciate it. Thanks Danilo
ok, here is the deal. i have the factory service manuals for 1986. it covers f150 to f350,
e150 to e350 as well as broncos. i looked through the manual and found a diagram listed as "Manual A/C-Heater System Vacuum Diagram and Selector Test". i believe this is what you need. i will post it as soon as i can. i am going to try and scan it right now.
Danilo, I thank you for that most helpful diagram, with your help I was able to isolate the problem, it is actually the mixing door at the beginning of the plenum, it has broke loose from the hinged part that is attached to the plenum. I was wondering if you had any tips, or directions on removing enough of the dash to get to this and replacing it. Thanks
Or are you looking for the climate control diagram?
What is missing/leaking?
Jim: I had looked for the emissions decal but could not find one. There was some of the emissions equipment missing so I am trying to get that put back together. Knowing that these decals on a van are often on the under side of the hood, this morning I removed the under hood insulation and found the decal there. Looks like I can figure it out from there.
Thanks
Thanks
tbruz
13
07-01-2021 10:53 AM
Ex-ChevyOwner
10-11-2015 10:18 PM
Mestrell
01-08-2013 09:13 PM
coledana138
10-21-2011 03:54 PM
