Upfitter Switch as Ignition Switch/Relay??
even then I don't know what wire Sandyc because without some research you may throw a code ?
depending on the year, the GEM, HEC, 4WD Control, ABS, VSM, SJB, etc, etc. They're all connected by one or more data busses, so they work together. But they are separate modules.
The easiest way to demonstrate this is to pay attention on a 2008+, when you turn the headlight switch from off to headlamps, there is a noticeable short delay in the lights coming on. The delay is caused by the clock speed of the processor in the PCM.
Here is a thread with info about converting the upfitter switches to "always hot" rather than only hot with the ignition on, it's just a matter of removing a relay and adding a jumper wire between two of the sockets where the relay was:
https://www.ford-trucks.com/forums/6...-switches.html
