using vin number for gear ratio?
Is it possible to assertain, from my VIN number, my gear ratio? 1979 F-250 4x4-bone stock
I had it jacked up in the rear due to a brake dragging issue and turned the driveshaft and observed the drum. It came out exactly to 2:1. Only one side was turning due to the other brake dragging. There is no tag on the cover or housing. I am positive it is not a 2.00 gear ratio.....any ideas?
I am absolutely positive it is bone stock from the factory with 66,400 miles. Thanks.
No... on the question.
I assure you it would take more than 2 turns of the driveshaft to get one turn of the wheel.
are you marking parts with chalk to make sure the count is correct ?
a 79 4x4 would have at least an 3.25:1 ratio and more like a 3.54:1 axle
Post the axle code shown on the warranty plate
You never mentioned axle tag info, maybe look for that as well
He did say it was missing.
My friend has a ford shop manuals for the 79 year that shows which codes mean what,.. axle ratio, trans type, transfer case, and so on... I'm not sure if I can get them as he is on a hunting trip, I will try to get these in the next few days. That is all the help i can offer at the moment. Maybe someone else on this wonderful website has access to these books?
1950FordF1
27
08-28-2016 12:04 PM
mossyoakford96
05-09-2012 03:15 AM
OutlawNomad
04-09-2012 09:59 PM
