inline 300 4.9 porting with pics pro porting - Ford Truck Enthusiasts Forums
Old 11-12-2010, 12:48 PM
kxkid661 kxkid661 is offline
kxkid661 is starting off with a positive reputation.
here are some instructions for the do it do it yourself at home porting specific to 4.9 inline 300 six, some shops get up to 1000 dollars to port this head ,it likes to eat up your bits, i went through 20 dollars worth of bits in the day it took to port this head . if you follow the pictures and instructions here you can pick up a nice power / torque boost and have a more efficient motor
velocity porting we want to keep the air speed up for torque ,keep the runners the same size runners are the passages.. from the manifold intake and exhaust manifold mounting surface to just before the bowls do not enlarge smooth the bump in center of the runner ceiling and casting marks to the side called Blending runners.
intake and exhaust bowls etc have thin metal to much porting and you will hit water
the goal with porting is to mold to ease restriction from the curves in port ,ideally if this 4.9 intake port was more of a perfect performance shape it would look like the traced outline in the lower pic.
porting 4.9 intake thin intake guide boss blend and smooth bowl smooth and straighten flow .stay away from floor/ceiling when porting this area
intake smooth and remove bumps from short side see pic ,the idea here is less of a sharp turn for the air and fuel to valve ..should look like the picture below when finished
[IMG][IMG][IMG][/IMG][/IMG][/IMG]
exhaust port below thin walls floor .etc if you remove to much here in the upper exhaust port guide area /bowl or runner you will have a hole to the coolant passages thin metal,just port out the .....thermector bump see pic... to be safe leave the rest in the exhaust port alone
[IMG][/IMG]
good luck porting happy holidays
if anyone needs porting service PM me
Old 11-12-2010, 05:37 PM
Harte3 Harte3 is offline
Harte3 is gaining momentum as a positive member of FTE.Harte3 is gaining momentum as a positive member of FTE.
Nice...just the kind of stuff I like to see.
Old 11-12-2010, 10:59 PM
montes57 montes57 is offline
montes57 is starting off with a positive reputation.
looks great. did you airflow bench test it prior to doing the work? Was wondering if that was possible so you can see your results after the fact. What type of bits were you using? I tumbled onto this site carbidebur.com seemed cool for ordering bits. Mind breaking down what bits you used, in order if possible? Is it important to port match the efi manifolds and runners from the intake to the head? what do you do in the valve seat area?
Old 11-13-2010, 12:23 PM
i recommend stones ...the steel carbide burr can cut to fast and then you will have a boat anchor ..no the efi manifold will not benefit from port matching to the head the manifold should stay smaller than opening at the head mounting surface ,the restriction there is the area inside the efi manifold ,needs to be cut open to enlarge it see pic
remove the bump in the ceiling of the intake runner only ..if you look in to the intake port from the window and use a flat ruler to find the hi and low spots remove the high spots in the runner .leave the gasket area alone smooth if you want , here is a article on the bowl area if you open up the bowl to much its a costly mistake
Porting Volume | Popular Hot Rodding Magazine Article at Automotive.com
Cylinder Head Porting Basics - Popular Hot Rodding Magazine
Old 11-13-2010, 12:31 PM
there is lot of flow to be had by deshrouding valves here is some information
Valve Shrouding
Ford GT40P Intake Port
Old 11-13-2010, 04:46 PM
AbandonedBronco's Avatar
AbandonedBronco AbandonedBronco is offline
AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.
Hey Kxkid,
Thanks for all of the information and help. This is great stuff, especially for those (like me) who plan on doing it at home.
I have a request though, and nothing personal. Could you clean up your writing a little bit? This type of information is very very specific and mistakes are costly, and your writing is rather difficult to understand. Again, nothing personal, I'm just having a difficult time understanding some of your explanations due to punctuation, etc., and I know it's good information that needs to be followed specifically.
Old 11-14-2010, 02:33 AM
i just printed out all those articles! cant wait to sit on my **** and take them in. I gotta lot to learn and this will help. Thank you to the both of you. When i get knowledge in the matter i can then decide if it is for me or farm out. Leaning on DIY. I enjoy my garage time. Its a killer winter project. Heat and beers and my ipod! I'll throw the honey do list right in the trash can!
Old 04-17-2011, 06:21 AM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is offline
muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.
look like a good job was done on those heads! any more pics? I would love to see some taken from looking down the ports. do you have any numbers as far as volume, cross section, or flow numbers?
also are there any more pictures on the cutaways for the 300's head? preferably one of each that you can see the entire port profile?
and I'm not sure about the intake... for dual throttle bodys it would be alright, but not optimal, and less so if it was used with non progressive two barrels (as far as street duty in a truck). I would personally add about an inch to the sides to increase the volume, and make a good raised radius on the ports and get them up off the floor of the plenum, the floor in that plenum is flat as can be and will hold alold of stagnent air. essentially making the port act alot smaller
Old 04-18-2011, 01:31 AM
Sounds like you are on the right track with the intake,i am currently working on a jaguar S porting project... the truck is only used for hauling bikes to the track,being i am in california gas price here at about 4.50 per gallon... out of all the porting mods deshrouding of the intake by far made the best torque .... good luck
Old 04-18-2011, 01:55 AM
jem44357's Avatar
jem44357 jem44357 is offline
jem44357 is starting off with a positive reputation.
Quote:
Originally Posted by AbandonedBronco View Post
Hey Kxkid,
2X on the clean up. If I had prior knowledge or an unassembled head sitting in front of me I think it would make more sense.
Thanks for sharing.
Jim
Old 04-18-2011, 10:46 AM
f100jim's Avatar
f100jim f100jim is offline
f100jim is gaining momentum as a positive member of FTE.
I doubt the OP did any flow bench testing. These pictures and information are all copied from various posts over on fordsix.com. The first two pictures, for example, were posted by the Frenchtown Flyer, the other were posted by various others.
Perhaps kxkid661 is none other than sam2007 who trolled the fordsix.com big six forum until he was banned? Just wondering.
Old 04-23-2011, 09:53 PM
82Blue's Avatar
82Blue 82Blue is offline
82Blue is starting off with a positive reputation.
He rides a k put number here) and661 is a gear company that I too am sponsored by
timing cover question truck7575 1999 - 2003 7.3L Power Stroke Diesel 15 01-05-2015 10:59 AM
photos from 2014 y block nationals pintoplumber 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 09-02-2014 11:19 PM
Ford Carlisle pictures pintoplumber 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 06-10-2014 02:59 PM
Offenhauser/Holley/EFI Manifolds/Exhaust (Pic's) overlandexpress 1961 - 1966 F-100 & Larger F-Series Trucks 10 10-08-2010 01:43 PM
Flowmaster Catback #2 dkf Modular V10 (6.8l) 7 09-16-2009 08:45 AM
Tags
300, 30l, 49, 49l, air, efi, ford, head, i6, inline, intake, manifold, port, ported, porting, tips
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
