1997 F-250 7.3(445cid)DI-Turbo Transmission
Actually the ZF 6 final drive is .72 whereas the E4OD is .71. The ZF 5S-42 final gear, at .76 or .77 depending, are low enough that it should make some difference. RPMs will be slightly higher than the auto but not so much as the 5 speeds. With 4.10s and auto I was cruising @ 70 mph around 2200ish. 4.10s and ZF 5, 70 mph about 2500ish. Now with 3.55s and ZF 5 I'm back down to 2100 at 70 mph and 1800ish at 65. I can only assume that although not much different the 6 speed will drop them some from what you see on a 5. But be advised even though the ZF 6 bellhousing bolts right up it requires a little fab work to get the whole driveline working together and fit under the truck. I've also been told, but not given concrete numbers, that the ZF 6 low gear isn't much different from our 5 speed low gear. Seems like when they made the 6 it just kind of spaced the gears out a little farther with the addition of an extra shift point. I personally like the drive of a 6 but not all do.
Thanks for the info on gear ratios. Where is a good place to find information like that?
Seems like it'd be too much work for a slight drop in RPM's. I don't want to change the axle gears because the 4.10's are great for towing my 22ft trailer.
I guess I should just spend the money on sound deadening mats for the cab, haha
The zf6 basically gave you another, taller, start gear than our first.
The Low on the 6 is about our first gear, a bit shorter.
Then first gear is still useless on them from what I found, unless your hauling, then its better than starting with such a short first like we have.
Somebody posted zf5 final drive other day, it was .75 or .76.
Though, I never remember seeing that the zf6's was that low. Can't remember everything.
Here's you a little concrete info on the 5. I can't find the same for the 6.
http://www.thedieselstop.com/faq/949...load/S5-42.pdf
the zf6 is just a pain to do in our trucks, if your REALLY bored then all power too you, but htere was a thread started on powerstrokenation of a guy doing the swap and it basically wasnt worth it, but i think it holds a little more power and it was fun too do. Basically you remold the floor boreds to take care of the clearance, the zf6 is a tall ****. but yeah theres essentially a 1mph difference in the gearing between the zf5 and 6
TonyMcCluskey
10-14-2014 11:27 AM
6.9lXLTf250
22
03-21-2012 12:46 AM
awils961
01-12-2011 03:50 PM
JoshWegener
08-26-2010 10:21 PM
