1988 ford f250 won't start - Ford Truck Enthusiasts Forums
Old 11-12-2010, 01:53 AM
dsands88 dsands88 is offline
dsands88 is starting off with a positive reputation.
Hey i think its my fuel filter because i ran it out off gas two days ago and now it wont start so i had to tow it home. (ran what i thought was normal for 2 days). Does any one have any ideas what else it could be?
Old 11-12-2010, 02:57 AM
any one? you can hear the fuel pumps priming and it cranks over but won't start
Old 11-12-2010, 07:17 AM
yak3d yak3d is offline
yak3d is starting off with a positive reputation.
What engine do you have in your truck, tell us a little more info that just a year and that it wont start.......
Old 11-12-2010, 04:54 PM
oh sorry its a 5.0
Old 11-12-2010, 05:07 PM
88 250's Avatar
88 250 88 250 is offline
88 250 is starting off with a positive reputation.
I had some what of the same problems I found out it was my Tank Selector Valve. Hope that helps and good luck!
Old 11-12-2010, 05:40 PM
ok and do i have to replace that or? and how do i see if it needs to be replaced
Old 11-12-2010, 05:54 PM
danr1 danr1 is online now
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
First put a fuel pressure tester on the fuel rail, see how much if any fuel pressure you have.
See if it falls within spec,
Engine off - 35 to 45 psi.
Engine running,
Fuel pressure reg vac line on - 30 to 45 psi.
Fuel pressure reg vac line off - 5 to 10 psi increase.
Volume test - low pressure pump - 6oz in 5 seconds.
Static pressure leakage check - remove power, verify that the fuel pressure remains within 5 psi of spec for 1 minute.
That should get you started, find an issue with any of the above let us know and can go from there.
Does the truck have spark?
Old 11-12-2010, 06:21 PM
88 250's Avatar
Do all the tests that Danr said first. I just bypassed mine because I only have 1 tank. I took mine apart and found a rubber o ring half out of place on mine. If youre going to pull the selector valve you're better off installing a new one as these do have problems and do go bad. But start with replacing the cheaper things first like fuel pressure regulator and fuel filter if your fuel pressure is out of spec.
Old 11-12-2010, 08:02 PM
ok so now ive realized that my truck isnt getting spark any ideas of what i should check?
Old 11-12-2010, 08:27 PM
88 250 i like you truck you should send me some pictures
Old 11-12-2010, 08:42 PM
Well the Ignition Coil, PIP – Profile Ignition Pickup and TFI – Thick Film Ignition module would all be suspect.
Your TFI module, it mounted on the dizzy? if so that be higher/highest on the list first best "guess".
Couple quick tests, verify power to the coil, should have battery voltage to it key in start and run positions.
Remove spout jumper and test for spark.
Old 11-12-2010, 09:27 PM
tfi module?
Old 11-12-2010, 09:34 PM
See> Ford Ranger/Bronco II TFI Ignition Diagnostics
Yea yea yea I know, its for a ranger/bronco 2, came up in a quick search for a link with a diagram showing location and basic diagnostics procedures, its the same for yours.
Old 11-12-2010, 10:45 PM
L. Ward's Avatar
L. Ward L. Ward is offline
L. Ward has a good reputation on FTE.L. Ward has a good reputation on FTE.
I would also be leaning towards the TFI module on the dizzy. Of course it never hurts to check all the connections to the coil, dizzy, etc
1953 f250 wont crank eaglesface123 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 05-02-2016 12:25 PM
f350 won't start nmaine 1999 - 2003 7.3L Power Stroke Diesel 8 08-14-2014 08:56 PM
Engine won't start obscurity 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 02-23-2014 05:20 PM
F650 Ran out of fuel!!! plz help vlaudi 6.0L Power Stroke Diesel 30 01-28-2012 07:43 PM
05 F550 won't start at times JerrywallaceII 6.0L Power Stroke Diesel 16 09-27-2011 08:06 AM
Tags
1988, 2003, 58, 73, 75, 88, diesel, f250, ford, fuel, pressure, shuld, start, w, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
