HOw much Oil does it need? - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 11-11-2010, 11:08 PM
ford2000ex ford2000ex is offline
ford2000ex is starting off with a positive reputation.
hey how's it goin i have a 2000 ford excursion 2wd, about 49k miles now... i use mobil 1 Extended Performance oil. ive taken it in, for it to get serviced and on the customer receipt it said they did a 7 quart oil change ? i usually do a 6 quart oil change by the ( Ex manual) is 7 quarts too much??? my dip stick reads at a good level at both 6 & 7th quarts ? what do u guys top it off at?
Old 11-12-2010, 01:22 AM
jh818's Avatar
jh818 jh818 is offline
jh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputation
I assume you have the V10. I put in about 6.5-7 qts. to top it off.
Old 11-12-2010, 09:56 AM
fgials's Avatar
fgials fgials is offline
fgials is starting off with a positive reputation.
Everything I read says 6 quartsbut thats crap. took 7 1/2qts to get to full mark on dip stick on mine. 6 barely read on stick and 7 would put halfway between full and low.
Old 11-12-2010, 10:14 AM
jh818's Avatar
Yup. Also, what size filter do you use? There are larger size filters that holds a bit more oil, if you know what I mean.
Old 11-12-2010, 12:25 PM
Old 11-12-2010, 01:19 PM
fgials's Avatar
Old 11-12-2010, 01:27 PM
tdappleman tdappleman is offline
tdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to all
It almost always seems to be above 6 quarts but it does seem to vary slightly by vehicle so start with 6 and add as necessary. After you start and check for any possible leaks, turn off the engine and let sit for about 5 minutes to let the oil drain down for the most accurate reading. Using the standard filter - FL820S or similar shape/size will usually be 6.5 quarts on most.
fgials - I would suggest anything but Fram and other low end filters. They are well known to collapse and restrict oil pressure. I certainly would not use one to accomplish an extended drain interval.
Old 11-12-2010, 01:34 PM
the oil i use lasts up to 15k miles... i put about 5k on it change it and put it in my wifes yukon... so basically,,,
Old 11-12-2010, 03:36 PM
fgials's Avatar
I change my oil every 5000 miles and have been using FRAM on my fleet rucks also with no problems.
Old 11-12-2010, 04:03 PM
No need to really debate it here - but I've seen first hand the problems caused by Fram. They will never be installed on any of my vehicles or my customer vehicles. There is plenty of data available online which you can review if you would like. The Motorcraft filter is only slightly more and worth it to me.
Old 11-13-2010, 02:10 AM
nyaristo nyaristo is offline
nyaristo is starting off with a positive reputation.
what oil are you guys using? i have been using synthetic blend. but by next month i am considering in switching to full synthetic....... what oil and filter brand should i use?
Old 11-13-2010, 07:14 AM
I am personally using Mobil 1 5w20 and the Motorcraft FL820S filter. Wix, Napa Gold, Purolator (makes Motorcraft) and Carquest Blue filters are also very good. I have a few customers running Amsoil and also Royal Purple in their 5.4 and 6.8's and are getting a lot of miles out of them. Use a good quality filter or you can restrict oil pressure and the engine will let you know with unpleasant noises.
Old 11-13-2010, 11:15 AM
Royal purple is exspensive do they sell 1gal jugs?
I'm also looking to do royal purple tranny fluid after winter! Does anyone know how many quarts the V10 trannys take in??
Old 11-13-2010, 07:44 PM
If you truly were able to change out all of the fluid then the 4R100 holds about 16 quarts depending on which pan is on there (4x2 or 4x4). Doing a drain and fill of just the trans pan is about 5.5 - 6 quarts. I believe the RP Max ATF only comes in quarts or in 5 gallon containers.
Old 11-13-2010, 09:25 PM
Quote:
Switch to mobil 1 fully synthetic extended performance . lasts up to 15k miles... but i usually switch it out at 5 then put in my yukon..
6 or 7 Quarts? DOOM173 Excursion - King of SUVs 12 07-02-2016 01:29 PM
oil capacity 6.7 lundman 6.7L Power Stroke Diesel 12 08-06-2012 12:51 PM
How much oil in 06 4.6L? abah 2004 - 2008 F150 3 07-02-2009 08:28 AM
352 oil capacity jd_sylvia 1961 - 1966 F-100 & Larger F-Series Trucks 3 02-17-2006 12:08 PM
Oil Capacity on 460 PHOTOG101 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 09-27-2005 11:59 PM
Tags
2002, 2004, 42, connect, excursion, explorer, fit, ford, fram, hm2, ky, lighting, need, oil, qts, transit, truck, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
