Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-11-2010, 06:37 PM
allwthrrider allwthrrider is offline
Garage is empty, add now
allwthrrider is starting off with a positive reputation.
Did I make A mistake?
I have a 1967 F250 that I'm putting a FE 390 into, since I don't have the time to rebuild it myself I decided to let the local High School auto shop class do it with close supervision from the shop teacher, nothing radical just want a good reliable motor for my truck, what are your thoughts?
  #2 (permalink)
Old 11-11-2010, 07:20 PM
Argess's Avatar
Argess Argess is offline
Argess is gaining momentum as a positive member of FTE.Argess is gaining momentum as a positive member of FTE.
I don't know. A lot of people go to the university to have dental students work on their teeth.
Stock rebuild? Probably be fine, although an oil leak or two might be expected.
  #3 (permalink)
Old 11-11-2010, 10:45 PM
Hypoid's Avatar
Hypoid Hypoid is offline
Hypoid is gaining momentum as a positive member of FTE.Hypoid is gaining momentum as a positive member of FTE.
The proof of the puddin' is in the eating.
You could always tear down and inspect the work before firing it up.
__________________
NO PRIDE-NO SHAME
'74 F-100 4x4: It's ugly, loud and smelly. Those are it's good points!
'96 Ranger XLT, 2.3L, 5-speed, 2 wheel drive.
Email me at Hypoids.haus at yahoo, visit me at RMFTC.com/forums
  #4 (permalink)
Old 11-12-2010, 02:38 PM
Mike G Mike G is offline
Mike G is starting off with a positive reputation.
You should be alright. Back in high school, I was one of those guys doing the work... For the most part, we worked on the instructors ride (a 68 Jeep commander with a 350 gm) or friends of his or the parts delivery fleet trucks. We never had anything come back.
__________________
Mike G
The Ford related items representing 1/3 of what's in the garage....
1965 F100 LWB 401FE power and C6
1968 Cougar XR7 (wife's toy)
2001 F350 Long-Crew-Dual-4x4-7.3L TD Hoss
  #5 (permalink)
Old 11-13-2010, 05:49 PM
RapidRuss's Avatar
RapidRuss RapidRuss is offline
FE "Freakin Expensive"
RapidRuss has a great reputation on FTE.RapidRuss has a great reputation on FTE.RapidRuss has a great reputation on FTE.RapidRuss has a great reputation on FTE.
Well whats done is done..you cant un-ring a bell... But personally I think I would have looked for a trade school, Vocational school or even a Community college...Before a high school.. the kids in the school might be able to work on the ricers..and unless the Instructor is an Old fart like me..He himself has probably only seen FE's in old Smithsonion Issues ! good Luck ! Keep us posted..
__________________
Blue Saphire 70 F250 436"CJ in Progress/Rollerized C6/4:10 Locker
Teal and Silver 96 XLT F150 4X4 302", EAOD, 3:55 Trac-Loc, Lock out Hubs, Daily Driver
Vista Blue 07 Mustang "Pony" 26K on the clock
  #6 (permalink)
Old 11-16-2010, 04:54 PM
Just by guessing I would say the instructor is in his early to mid 50's and sounded like he was familiar with the FE's
  #7 (permalink)
Old 11-25-2010, 01:26 PM
wagonerkl wagonerkl is offline
wagonerkl is starting off with a positive reputation.
When I was in HS (a million years ago), I had all my work done by classmates in Auto Shop. Everything from valve jobs to total rebuilds: never had a problem. Lets face it, basic engine rebuilds are cook-book. If you have the correct equipment and follow the procedure it will turn out fine. AND, you are giving the kids something to learn on. That should be worth something.
Please let us know how it turns out.
  #8 (permalink)
Old 12-04-2010, 10:51 PM
Argess's Avatar
Well? What progress has been made? Still think it's a mistake, or still unsure?
  #9 (permalink)
Old 12-17-2010, 05:46 PM
Update, motors apart all cylinders mic out to factory specs but rings were shot in a couple cylinders { must be where my oil loss was} took block to machine shop & they confirmed the cylinder wear, going to bore .020 over go with new pistons and Moly rings, Heads are done and were in good shape nothing serious ,Students have the other parts sandblasted for me so while their off for 2 weeks going to try and get everything painted.
  #10 (permalink)
Old 01-04-2011, 05:01 PM
Just found out today that the machine shop thinks someone used scotch brite with a grinder on the block so now I need to have the block decked
  #11 (permalink)
Old 01-04-2011, 05:12 PM
Argess's Avatar
Oh well....maybe the 10 thou will give you a little Hp boost......
  #12 (permalink)
Old 01-04-2011, 07:04 PM
Okay, I'll bite...What does ScotchBrite do to the block deck. It seems to me that would have a very mild if any effect on it unless someone REALLy tried to cause damage. Did they give a measurement for the difference? I am not pretending to know anything here, just trying to learn what other people know. Thanks.
  #13 (permalink)
Old 01-04-2011, 08:22 PM
He said that the scotchbrite removed metal, The machinist sprayed graphite on the block then ran a file lightly across it & you could see the high spots, felt it was enough to worry about gasket sealing properly
  #14 (permalink)
Old 01-04-2011, 09:32 PM
69cj 69cj is offline
69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of
Quote:
If they don't have hardened valve seats, for unleaded fuel, nows the time to do them.
__________________
"05 F-250, 6.0, CC, LB, 3.73, 4 X 2, Lariat, with coolant filter and Bilstein shocks, Magnefine p.s. filter, Ford fuel press. spring upgrade and ScanGauge ll. S. Ca.
"69 Mustang, Mach 1, 428 CJ, Ram Air, Stock
2007 FHLP H.D. Road King
2007 Thor Jazz 5er, 11k dry weight, 31'
173rd Abn. RVN.
  #15 (permalink)
Old 01-05-2011, 12:02 AM
My book says,"If deck warpage exceeds .003 inches in any 6 inch span, or .006 in total, then the block deck must be machined flat." I would assume this means a gasket can effectively fill up to those variations WITHOUT machining. I am NOT a machinist...I just find it odd/entertaining that you can get so many different "RIGHT" answers when you ask different machinists.
Tags
2007, 302, 428, 90, cj, f250, ford, jazz, magnefine, oil, pressre, psi, specifications, thor, trailer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
