Front Drive Shaft Repair Tips - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-11-2010, 06:08 PM
5.4L to Freedom's Avatar
5.4L to Freedom 5.4L to Freedom is offline
5.4L to Freedom has a good reputation on FTE.5.4L to Freedom has a good reputation on FTE.5.4L to Freedom has a good reputation on FTE.
Finally got around to dealing with my front driveshaft today, and there were quite a few things I learned so far that should be common knowledge for a lot of us and I'm not sure are, thus I'm posting my findings.
As most of us know, our front drive shaft contains 3 sealed U-Joints. 1 at the axle end, and 2 at the transfer case end inside a double cardan joint. However within the double cardan joint (inside the casting, between the 2 u-joints) the is a centering ball... essentially a mini-ball joint with needle bearings inside it.
From all the shops I talked too today, 9/10 times when people believe the u-joints in the front drive shaft are shot, it is ACTUALLY the centering ball that is bad. In my case the centering ball and 2 u joints were toast.
Now, coming across a new centering ball isn't the easiest part to come by. The only people I know to stock it are Napa and Car Quest. I picked one up for $36 and change, despite local repair shops wanting around $70-100 for it.
However replacing the centering ball is not the easiest DIY job, and should be taken to a place with a machine shop... your average muffler man, belle tire, etc. DO NOT have the capacity to change it... whether they know that or not is a different story. Just save yourself some time and either go directly to a driveline shop or an auto shop with a full machine shop. I got quoted today that if I furnished all parts (which I did) it is about $30 worth of labor with the right tools. The other shops capable of changing it wanted to charge me 2 hours labor to change it and the U-Joints... which results in $100-$200 labor bill depending on the shop.
So if you need your front driveshaft repaired, a little bit of shoppin around will pay off big. Try to find an old timer who's used to old trucks and they wont charge too much at all!
Old 11-11-2010, 06:25 PM
bill11012's Avatar
bill11012 bill11012 is offline
Modular motor junkie
bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.
I found that mine is bad yesterday.
The centering ball, all three U joints and the part that couples with the centering ball are all worn out.
Old 11-12-2010, 08:13 PM
bill11012's Avatar
The centering ball is $125 and the Part that couples with the U joint is $61 from my Car Quest.
How are you getting them so cheap?
Old 01-16-2011, 07:40 PM
KRDiesel's Avatar
KRDiesel KRDiesel is offline
KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.
Resurecting from the dead
Do we have a part number on the centering ball?
Old 01-17-2011, 08:13 AM
I'll dig around and find the part number this evening... it was definitely not $125 and I'm nobody special so i dont know what's up.
Rebuilding a Double Cardan Joint (Vid/Pics) CPUNeck 1999 - 2003 7.3L Power Stroke Diesel 36 05-20-2016 10:33 PM
2008 F250 Std. Cab RWD U-Joint swap. TexasRebel 1999 to 2016 Super Duty 0 06-22-2014 10:24 PM
Double Cardan CV joint rebuild? deere55 1987 - 1996 F150 & Larger F-Series Trucks 7 09-03-2012 10:24 PM
double cardan joint SteveO. 1999 to 2016 Super Duty 2 10-07-2011 08:10 AM
Double Cardan Center Ball Stud rlh Clutch, Transmission, Differential, Axle & Transfer Case 2 01-23-2004 01:18 AM
Tags
ball, car, cardan, double, drive, driveshaft, duty, f350, ford, front, joint, quest, repair, reviews, shaft, super, superduty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
