A piller grab handle - Ford Truck Enthusiasts Forums
Old 11-11-2010, 05:39 PM
CLR f-150's Avatar
CLR f-150 CLR f-150 is offline
CLR f-150 is starting off with a positive reputation.
Hey guys Im not sure if anyone has found a way to put a handle on the a pillers on these trucks, but I found a way. I took a handle off a 96 explorer, drilled two holes through the trim pieace and into the a piller, took 2 1 inch screws and fastened it down. Now for the test, I think that the handle will break before the screws will give, but i got three more handles just incase. If anyone wants to see it mounted I got a couple of pictures in my gallery in my profile, check um out and let me know what you think.
Old 11-11-2010, 06:23 PM
L. Ward's Avatar
L. Ward L. Ward is offline
L. Ward has a good reputation on FTE.L. Ward has a good reputation on FTE.
Thumbs up
Sweet!! Looks like time for another trip to the pull-a-part for me!!
Old 11-11-2010, 07:33 PM
CWPottenger CWPottenger is offline
CWPottenger is gaining momentum as a positive member of FTE.
I must be looking wrong.... I don't see a picture of handle...
Old 11-12-2010, 04:40 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
I don't see a picture of it either, but I do like this idea.
Old 11-12-2010, 05:18 AM
L. Ward's Avatar
Old 11-12-2010, 05:36 AM
CLR f-150's Avatar
sorry for confusion, Im not to sure how to put the pictures into my post. Like ward said there in my album with the truck on it.
Old 11-12-2010, 08:52 AM
jimjoebob99 jimjoebob99 is offline
jimjoebob99 is gaining momentum as a positive member of FTE.
I've been thinking about this for a while. I want to put them either on the A pillar or on the roof above the window on the doors. Does anyone know of any aftermarket kits for something like this? I would just hope that with sheet metal screws, drilled into the A-pillar that the threads wouldn't rip out and defeat the purpose. Did you go all the way through to the outside of the cab?
Old 11-12-2010, 05:00 PM
Thats cool. My only concern is that tightening up the handle will deform or brake the A piller trim.
Old 11-12-2010, 06:11 PM
CLR f-150's Avatar
well I drilled into the a piller from the inside and used 2 number 10 or 12, 1 inch screws. The problem being the a piller is on a 45 degree angle and its hard to drill into it. If I see a problem with the trim cracking I will probably take a pieace of wood and make a spacer to go from the piller to the handle. It wont get used to much as I dont have passengers to often, let me know if any of you try this and have any problems. This only took me about 10 minuets to do.
Old 11-12-2010, 09:27 PM
L. Ward's Avatar
Looking at the picture, I am thinking maybe taking the handle and using it as a template on the trim panel, making an outline and then carefully cutting it out with a dremel so that the grab handle sits flush to the pillar
Old 11-13-2010, 12:23 AM
GreenBastrid95 GreenBastrid95 is offline
GreenBastrid95 is starting off with a positive reputation.
It works!
I have done the same thing in the lat 2 trucks I have had. I got some buddys who are short and heave and they have always held. It is hard to drill them for sure but it can be done use a punch to make a pilot mark. As for trim breaking it hasnt happend to me. It seems pretty flexible in that area.
Old 11-13-2010, 05:35 AM
CLR f-150's Avatar
you cant mount it flat to the piller because its on an angle, so you need to make a spacer on a 45 degree angle. Take off the trim piece first before you drill holes and see what you can do.
Old 11-13-2010, 10:22 AM
f1504x4driver's Avatar
f1504x4driver f1504x4driver is offline
f1504x4driver has a good reputation on FTE.f1504x4driver has a good reputation on FTE.
did this on mine a few years ago with one of those universal handles you can buy at the local parts store. If you buy some universal shock bushings( they are in the help line, the red carded parts) you can put the bushings on back of the trim and run the screws through them. They will give when you tighten down the a pillar trim and give support to the handle. no vibration or cracking so far.
Old 09-17-2016, 09:30 PM
Chief5204 Chief5204 is offline
Chief5204 is starting off with a positive reputation.
Hi. Looking to add grab bars to my '94 F350 Crew Cab. Any measurements as far placement would sure be helpful. Thanks.
Old 09-19-2016, 03:12 PM
LeoJr's Avatar
LeoJr LeoJr is offline
LeoJr has a good reputation on FTE.LeoJr has a good reputation on FTE.
I put mine overhead, but more forward than centered. Follow the link in the signature file below. One of the first mods I did.
08 door panel swap mdayz28 1999 - 2003 7.3L Power Stroke Diesel 27 11-19-2013 11:20 AM
A piller grab handle iredvette 1997-2006 Expedition & Navigator 11 09-11-2010 06:25 PM
Where to buy gauges and piller XBAJBUSX 1994.5 - 1997 7.3L Power Stroke Diesel 9 02-23-2010 06:08 PM
Mounting tweeters in door "sails" isubsmith Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 21 02-16-2007 12:30 PM
Painting gauge piller pod Help. timmosazz 1994.5 - 1997 7.3L Power Stroke Diesel 13 07-12-2006 07:40 AM
Tags
45, 94, 96, angle, bronco, degree, f150, ford, grab, handle, lighted, picture, pillar, towers, truck, trucks, twin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
