Catalytic converter removal?
Old 11-11-2010, 01:36 PM
CammyV's Avatar
CammyV
CammyV is offline
I have an '08 F-150 with the flex-fuel 5.4l, I'm trying to redneck it up a bit. Recently i unbolted the stock exhaust just before the muffler, and put on a straight through muffler, but I'd like a bit more noise. How many cats (if any) can be cut out without throwing codes, and are there sensors in all of them?
Old 11-11-2010, 02:22 PM
bridge's Avatar
bridge
bridge is offline
Sick 'n Tired
Two cats, with a sensor before and after each. Can't take one out without throwing a code.
Old 11-11-2010, 08:02 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
FYI its illegal to remove any cats and they are very expensive to replace. Also if you take any out it will "throw" a code. The PCM monitors both cats for efficiency.
Old 11-11-2010, 10:20 PM
CammyV's Avatar
CammyV
CammyV is offline
ah, I guess I should just get used to the sound I've got!
Old 11-12-2010, 07:36 PM
Still Smoking's Avatar
Still Smoking
Still Smoking is offline
I always thought the o2 sensors were in front of both cats. Well thats what someone told me
Old 11-12-2010, 07:41 PM
Coskid's Avatar
Coskid
Coskid is offline
If you put a straight through muffler on it and didn't get enough noise out of the truck then you are deaf. Maybe try adding a larger pipe to get some more noise.
Old 11-13-2010, 06:56 AM
bridge's Avatar
bridge
bridge is offline
Sick 'n Tired
Nope, one fore and aft of the cat. The sensors let the PCM know if the cat is working efficiently. If they're not it throws a code and you can't pass inspection.
Old 11-13-2010, 09:53 AM
Bobs55effie's Avatar
Bobs55effie
Bobs55effie is offline
Other than throwing a code and the inspection... is there any mechanical problems with removing the cats?
Old 11-13-2010, 09:55 AM
bridge's Avatar
bridge
bridge is offline
Sick 'n Tired
Mechanically, no. Federally, yes!
Old 11-13-2010, 04:58 PM
belldawg's Avatar
belldawg
belldawg is offline
dump the exhaust as close to the cab as you can and it'll be louder than running it out by the tailgate. I wouldnt end it under the cab though or you'd have all the fumes running into it.
Old 11-13-2010, 05:07 PM
n5926g's Avatar
n5926g
n5926g is offline
Unless one of the cats is bad,leave them alone...if it is replace it.Removing them will cost you economicaly,and definately cause issues down the road.
Old 11-13-2010, 05:14 PM
1bad67sbf's Avatar
1bad67sbf
1bad67sbf is offline
what about a set of high flow cats and look at the exhaust cutout's one 2.5 before the muffler that would redneck it up a little but you can go back to normal exhaust when you want to. (im looking at this one)
BadlanzHPE Electric Exhaust Cutout Cutouts 2.5 INCH S: eBay Motors (item 180375536259 end time Nov-21-10 15:39:35 PST)
Old 11-13-2010, 09:38 PM
CammyV's Avatar
CammyV
CammyV is offline
I kept the original exhaust diameter (2.5") and have a 30" tailpipe after the muffler (installed backwards to bypass the baffles), which dumps straight down in front of the back axle. Maybe I would hear it better if I turned down the music
I appreciate all the responses, and I suppose I will just leave the cats alone, and be glad that the law hasn't told me to quiet it down, or remove the second round of tint this year.
Old 11-13-2010, 11:03 PM
FordMstrTech's Avatar
FordMstrTech
FordMstrTech is offline
This is the cheapest and quickest way to get some major racket. Be sure to weld on a turn down, piped curved pointing to the ground, if you dont u will wind up rustin out the bottom of the body...
Old 11-24-2010, 09:10 AM
BII Plow Truck's Avatar
BII Plow Truck
BII Plow Truck is offline
Originally Posted by CammyV
.......which dumps straight down in front of the back axle.
Another bed floor rust canidate
Quick Reply: Catalytic converter removal?
