HELP ASAP!!!!!!!!!!!!!!!!!!!!
im about to shove this truck off a cliff (however with my luck it would drive itself back to me) i have a 91 half ton with the 300 and 4 on the floor, recently i took out my dash to do a giant clean up job, i put everthing back together as i found it, about 36 hours later the headlights were getting dim and the truck was running odd, i determined it must be the alternator, so i took it in to have it tested, it tested at 9 volts (clearly not enough) got a new alternator, problems persist!!!!!!!!!!!!!!! help!!!!!!!!!!!! i checked all the alternator wiring
the truck stays at about 12.6 volts and idles/runs on about 12.4..... help me, the baterry slowly drains and ... ugh i just wanna run this thing off a cliff
Check the wiring pigtail just behind the headlamp switch, and check the wiring pigtail at the alternator especially the one at the alt. as they actually reccomend replacing that harness (Major shorting issues that actually created fires) when changing an alt during that generation Ford truck....
I have some electrical troubleshooting help here;
Ford Truck Enthusiasts Forums - Grubbworm's Album: Troubleshooting help, for anyone that needs it.
Just let me know if it helps.
well, figured out the problem, and youll never guess what it was, one of the plugs behind the gauges that controls the left side, wasn't plugged in all the way!!!!!!!!!!!!!!!!!!!!! and thats what was causing my battery not to charge!!!!!!!! can you believe that?!?!?!?!?!?! oh well, its fixed now
jonnygorgo
29
03-12-2014 06:36 PM
garydmundy
11-25-2013 09:45 AM
bkvanbek
01-10-2011 06:35 AM
sniper250
09-19-2010 11:17 AM
