overhead console not working - Ford Truck Enthusiasts Forums
Old 11-11-2010, 08:04 AM
GeorgeNteri GeorgeNteri is offline
GeorgeNteri is starting off with a positive reputation.
I have a problem that my overhead console gas gauge/milage to empty and compass just suddenly went out. I do not have a manual on my excursion 2003 with the v 10 i was wondering if someone could tell me the fuse and or relay location it uses. i beleve it is just a blown fuse or relay that went out. thanks in advance for the help.
Old 11-11-2010, 10:12 AM
walt501 walt501 is offline
walt501 is gaining momentum as a positive member of FTE.
Check the fuse. But from what I have read the problem is most likely the circuit board that is located in the overhead console has dropped a few electrical components. Since this circuit board sits right under the roof, the sun can heat the solder on the circuit board to the point that electrical components literally drop right off the board. I have read of many people that have disassembled their overhead console and re-soldered the electrical pieces (resistors, etc.) back into the board which fixed the problem.
Old 11-11-2010, 05:21 PM
chazman chazman is offline
chazman is starting off with a positive reputation.
Old 11-11-2010, 05:25 PM
Old 11-11-2010, 05:26 PM
Old 11-28-2010, 05:05 AM
TheBestKindOfEX's Avatar
TheBestKindOfEX TheBestKindOfEX is offline
TheBestKindOfEX is gaining momentum as a positive member of FTE.TheBestKindOfEX is gaining momentum as a positive member of FTE.
Nice photos
Quote:
Originally Posted by chazman View Post
Thanks for taking the time to post the pics. I pulled mine once but did not dig that far. Now I know where to look!
Old 11-28-2010, 08:59 AM
FIXED ! ....for now
This forum has paid off many times over. I applied the soldering iron to the 3 little parts in the pics. I only heated them and allowed the solder under them to re-attach. I didn't think I could get more solder in there without chancing ruining something. I suspect they will come loose again sometime.
Old 11-29-2010, 11:26 AM
RMBC Freeride's Avatar
RMBC Freeride RMBC Freeride is offline
RMBC Freeride has a good reputation on FTE.RMBC Freeride has a good reputation on FTE.
Reps to chazman for the links on this! This question comes up time and time again, and I never seem to have a good link handy.
Old 09-02-2012, 05:48 PM
gneill794 gneill794 is offline
gneill794 is starting off with a positive reputation.
Quote:
These threads out here have been very helpful for me! I am now stuck, 4 of my resistors had one side lifted and I was able to get them soldered back down. HOWEVER, behind the pink capacitor disk, there's a yellow component (I believe) which has burnt out on mine. All of the pictures I have found have the disc bent over it!!!! ... would anyone know what the specs are on that component!?
Thanks in advance,
George
Old 09-06-2012, 09:47 PM
kornfanjoe's Avatar
kornfanjoe kornfanjoe is offline
kornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant future
i took my monitor apart and couldnt notice anything wrong on the computer board but i did notice on the corner of the display screen on the side where the connections are that the glass looks like there was a burn unside of it similar to the look fuses get after blowing. my compass is intermittent and im thinking that this is the problem. has anyone else had similar experiences?
Old 09-06-2012, 11:33 PM
Stebs Stebs is offline
Stebs has a very good reputation on FTE.Stebs has a very good reputation on FTE.Stebs has a very good reputation on FTE.Stebs has a very good reputation on FTE.
I think the burn is normal, I had it on mine... Look at the little resisters behind the display very carefully and look at their solder points on them very carefully as well. All of mine looked good, and then i noticed a hairline crack in one of the solder joints. Hit it with the soldering pencil and put it back together, no problems since...
Old 09-07-2012, 12:45 AM
ROBBINthaHOOD's Avatar
ROBBINthaHOOD ROBBINthaHOOD is offline
ROBBINthaHOOD has a great reputation on FTE.ROBBINthaHOOD has a great reputation on FTE.ROBBINthaHOOD has a great reputation on FTE.ROBBINthaHOOD has a great reputation on FTE.ROBBINthaHOOD has a great reputation on FTE.
I had issues with mine and found 2 of the little resistors were loose, resoldered them and it worked but now it only works when it wants to. Once it comes on it stays on for the whole duration of the drive but sometimes it might not come on for a good 10-20 minutes and other times it comes on right at startup, dont know if its in the wiring as my rear vent windows work when they feel like it also. Blasted electrical gremlins!!!
Old 09-08-2012, 03:43 PM
sammatt1's Avatar
sammatt1 sammatt1 is offline
sammatt1 is gaining momentum as a positive member of FTE.
Mine overhead display has not worked almost a year now and thanks to this thread mine is working again. Very easy job, had to solder four chips --- hardest part was keeping a steady hand while soldering and looking for the screw I dropped. Thanks guys.
Old 07-27-2014, 11:51 AM
jandlstables jandlstables is offline
jandlstables is starting off with a positive reputation.
Overhead console repair
Pulled mine apart today and found 2 of the chips laying in the bottom. soldered them back on and mine is working again.
Old 04-08-2016, 10:17 AM
TinMan289 TinMan289 is offline
TinMan289 has a good reputation on FTE.TinMan289 has a good reputation on FTE.
It took me longer to read through this thread and the directions than it did to fix the problem! Just loose, easy solder touch-up.
Reps inbound!
02 F250 Overhead Console Gone Out NDrum2005 1999 to 2016 Super Duty 286 02-28-2017 01:29 AM
No power to overhead console!! Brandiesel928 6.0L Power Stroke Diesel 3 02-19-2017 12:27 PM
Please post pics of your overhead console! Stewart_H Excursion - King of SUVs 33 01-04-2017 07:17 AM
Overhead console ligito 1999 to 2016 Super Duty 3 11-08-2015 11:31 PM
2003 F250 Overhead Console Display lvm1114 1999 - 2003 7.3L Power Stroke Diesel 5 07-23-2006 03:10 PM
Tags
2001, 2003, 2005, 99, computer, console, diesel, duty, excursion, f150, f250, ford, fuse, overhead, part, quit, super, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
