Cab On Engine Removal and Head Gaskets - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-11-2010, 12:59 AM
holdendaniels holdendaniels is offline
holdendaniels is starting off with a positive reputation.
I started today removing my diesel 6.0 engine because I need to replace my Head gaskets. My 2005 F250 with 137K miles has been puking coolant and overheating under load. 5000 miles ago, I replaced the EGR cooler and oil cooler with the Bullet Proof Diesel EGR kit. I initially was going to just remove the heads with the cab on. But my engine leaks a little oil from the bed plate and I decided if I am going to do all this work, I should just pull the engine and so I can fix all the problems. My plan is to replace the HGs and use ARP studs. While I have the engine out also going to replace, the bed plate gasket, oil pan gasket, front and rear main seals, replace water pump, serpentine belt tensioner and any other problems I come across. I started to today and here are the pictures. Hopefully, I will have the engine ready to pull tomorrow. I will need some help along the way and will be asking for advice.
<center>
<a href="http://s556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/?action=view&current=IMG_2793.jpg" target="_blank"><img src="http://i556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/IMG_2793.jpg" border="0" alt="Photobucket"></a><br /><br />
<a href="http://s556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/?action=view&current=IMG_2796.jpg" target="_blank"><img src="http://i556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/IMG_2796.jpg" border="0" alt="Photobucket"></a><br /><br />
<a href="http://s556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/?action=view&current=IMG_2797.jpg" target="_blank"><img src="http://i556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/IMG_2797.jpg" border="0" alt="Photobucket"></a><br /><br />
<a href="http://s556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/?action=view&current=IMG_2798.jpg" target="_blank"><img src="http://i556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/IMG_2798.jpg" border="0" alt="Photobucket"></a><br /><br />
<a href="http://s556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/?action=view&current=IMG_2799.jpg" target="_blank"><img src="http://i556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/IMG_2799.jpg" border="0" alt="Photobucket"></a><br /><br />
<a href="http://s556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/?action=view&current=IMG_2800.jpg" target="_blank"><img src="http://i556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/IMG_2800.jpg" border="0" alt="Photobucket"></a><br /><br />
<a href="http://s556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/?action=view&current=IMG_2801.jpg" target="_blank"><img src="http://i556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/IMG_2801.jpg" border="0" alt="Photobucket"></a><br /><br />
<a href="http://s556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/?action=view&current=IMG_2803.jpg" target="_blank"><img src="http://i556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/IMG_2803.jpg" border="0" alt="Photobucket"></a><br /><br />
<a href="http://s556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/?action=view&current=IMG_2806.jpg" target="_blank"><img src="http://i556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/IMG_2806.jpg" border="0" alt="Photobucket"></a><br /><br />
<a href="http://s556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/?action=view&current=IMG_2807.jpg" target="_blank"><img src="http://i556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/IMG_2807.jpg" border="0" alt="Photobucket"></a><br /><br />
</center>
Old 11-11-2010, 01:15 AM
I have a set of factory workshop books which should help a lot but would like help from others who have done this before and can add to this post. I took the front wheels off the truck as you can see in the pictures and placed the truck on a set of 4x4s which made it a lot easier to work on.
Old 11-11-2010, 09:16 AM
Fishin76's Avatar
Fishin76 Fishin76 is offline
Fishin76 has a good reputation on FTE.Fishin76 has a good reputation on FTE.
subscribed.......
Old 11-11-2010, 09:21 AM
Dirtfarmer69's Avatar
Dirtfarmer69 Dirtfarmer69 is offline
Dirtfarmer69 is starting off with a positive reputation.
Wow, very ambitious. We are all hoping to see lots of pictures.
Old 11-11-2010, 03:01 PM
ExplorHer1369's Avatar
ExplorHer1369 ExplorHer1369 is offline
ExplorHer1369 is starting off with a positive reputation.
I agree. Great progress so far.
That's a very nice garage you have there as well.
Old 11-11-2010, 03:16 PM
mwsF250 mwsF250 is offline
mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.
Good on you!
It pains me to see how few people have the self confidence and motivation to tackle things like this on their own any more. Our forefathers have turned over in their graves so many times that some (Franklin and Emerson come to mind) are probably wearing through their caskets by now....
Old 11-11-2010, 03:29 PM
fz1dave's Avatar
fz1dave fz1dave is offline
Super Duty
fz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud of
At least you aren't under a tree. Nice garage!
Old 11-11-2010, 04:05 PM
millboy millboy is offline
millboy is starting off with a positive reputation.
How much did you lower the front by removing the front wheels? That looks like a great idea.
Old 11-11-2010, 04:19 PM
woodlander's Avatar
woodlander woodlander is offline
woodlander is gaining momentum as a positive member of FTE.
Nice pics, how much time to get where you are at?
Old 11-11-2010, 06:58 PM
clem1226's Avatar
clem1226 clem1226 is offline
clem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to behold
where are all the parts going, through the process so far the garage has stayed immaculate?
nice work
Old 11-11-2010, 07:30 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
subscribing..I would be putting the parts in the bed of the truck if it were me. Great idea to remove the front wheels. I would have pulled the hood as well if it were me.
Old 11-11-2010, 08:39 PM
Day 2 went well. Pulled the intake manifold, EGR cooler, turbo exhaust pipes, AC compressor, PS pump, wiring harnesses, starter, removed bolts to torque converter and bell housing. The engine is now sitting in the truck looking like a long block ready to be pulled tomorrow morning. I have about 12 hours into this project so far. I have been following the Factory shop manual directions and not to bad. I have been putting the removed parts in my garage and outside, the ones that won't be damage by being there. Putting the truck on 4x4s on the floor has helped a lot, I am guessing dropped the front end down 12" to 18". Everyone thanks for the encouragement! I will post more pics with tomorrows progress.
<center>
<a href="http://s556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/Engine%20Removal%202nd%20day/?action=view&current=IMG_2809.jpg" target="_blank"><img src="http://i556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/Engine%20Removal%202nd%20day/IMG_2809.jpg" border="0" alt="Photobucket"></a><br /><br />
<a href="http://s556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/Engine%20Removal%202nd%20day/?action=view&current=IMG_2813.jpg" target="_blank"><img src="http://i556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/Engine%20Removal%202nd%20day/IMG_2813.jpg" border="0" alt="Photobucket"></a><br /><br />
<a href="http://s556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/Engine%20Removal%202nd%20day/?action=view&current=IMG_2812.jpg" target="_blank"><img src="http://i556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/Engine%20Removal%202nd%20day/IMG_2812.jpg" border="0" alt="Photobucket"></a><br /><br />
<a href="http://s556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/Engine%20Removal%202nd%20day/?action=view&current=IMG_2816.jpg" target="_blank"><img src="http://i556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/Engine%20Removal%202nd%20day/IMG_2816.jpg" border="0" alt="Photobucket"></a><br /><br />
</center>
Old 11-11-2010, 09:07 PM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
Nice work. Be careful pulling that lump of iron out, its heavy! What are you going to sit it on when its out?
Old 11-11-2010, 09:28 PM
RickBraden RickBraden is offline
RickBraden is starting off with a positive reputation.
Great job so far & very good pictures. Digital cameras are great for this sort of stuff. Personally I think it's a crying shame that a truck with those miles should require any of this. If I owned Ford I'd pay you off just to keep your problems quiet. I,m betting that almost any gas engine would have had few if any problems & at a fraction of the cost per mile. Terrible shame!
Way to go guy!
Old 11-11-2010, 11:37 PM
fordmanbrad's Avatar
fordmanbrad fordmanbrad is offline
fordmanbrad is starting off with a positive reputation.
WOW, is that a complicated engine bay. I've done a few engine/transmission jobs over the years, but this job is really daunting.
I can see by your truck and your garage that you are the type that takes good care of things, so as others have said, this is a total disgrace that Ford built something so trouble prone AND difficult to repair.
I can imagine the anticipation when its all back together and you turn that key...........
1978 Midnight Jade Ranger Explorer restoration. shanes66charger 1973 - 1979 F-100 & Larger F-Series Trucks 81 05-25-2016 03:49 PM
Time to introduce the new Escape Mark250 Escape & Escape Hybrid 2 04-03-2015 12:48 PM
Newb here, new owner of a 51 f1 Armedsvt 1948 - 1956 F1, F100 & Larger F-Series Trucks 22 12-23-2014 10:20 PM
Something tells me this is a bad idea macattack Fifth Wheel & Gooseneck RV Towing 19 07-19-2012 09:26 PM
When there just isn't ANY room for your exhaust... Blueoval_boy_64 Offroad & 4x4 47 12-13-2009 11:17 PM
Tags
05, 200, 2004, 2005, 350, cab, change, engine, f, f250, ford, gaskets, head, removal, removale, sd, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
