My truck started running very rough so i changed the fuel filter and the same thing so a ford dealer ship said i needed to take the filter back out and fill the bowel up with fuel and then put the filter back in and now it wont even start what have i done wrong? pls help
i did read in a similar thread not long ago, that the heater could come loose and ground out just enought o cause a no start but not blow the fuse. i think the problem ended up being a bad pcm
if you are sure your battries a fully charged, i would jump the 2big terminals on the glow plug relay for 30 sec, then try it. the white smoke is unburnt fuel
I droveit about 60mileswith it running like **** and now afteri took the filter back out and filled it with fuel andput the filter back in it just wont start and it was around 70 today so not cold
