I have a few, I only did a cam swap, and the other go fast goodies got put on 3 years ago after I had so many problems with the old 1bbl carb.
Then here's my nephew's, which is much more drool worthy:
Hey I had no Idea you were on the FTE forum. I just replied to your youtube video. On there Im gunsmithMMG. Glad to see you on here. As you can see im still doing cam research.
This is not my engine. I copied this photo from someone on this forum, and I hope they don't mind me reposting it. This is the best looking 300 I have seen. A lot of attention went into every detail and it shows. Enjoy.
I used the rustoleum hi heat paint. It is rated for 2000 degrees i think. I sanded them down with a wire wheel and painted and baked them in the oven per their directions. I have had about 4 heat cycles on them so far and they still look good. Some slight discoloration, but still better then rust colored.
You guys are doing some nice work anyone have any more pics of this one from different angles?
