Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks Discuss the Early Eighties Bullnose Ford TruckSPONSORED BY:
  #1 (permalink)
Old 11-10-2010, 01:25 PM
pureanimal pureanimal is offline
Garage is empty, add now
pureanimal is starting off with a positive reputation.
mounting meyer plow from 1990 gmc to 1980 ford f250
I am looking for any help I can get. I am trying to mount a conventional meyers plow from a 1990 gmc k1500 to a 1980 ford f250c. Does anybody have the dimensions of the mounting plates that I would have to make to put on the ford frame to make this plow fit or any other modifications that I would have to do?Any help is greatly appreciated!!!
  #2 (permalink)
Old 11-10-2010, 04:20 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
1989 Ford F-250
Franklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud of
I have made custom mounts before. You basically hold the unit up to the truck with a lift and blocks, and see what you need and fab it up. Each situation is different.
The easier quicker way would be to buy the proper mount from your local Meyer dealer. Most Fords from 80-96 where the same, and take the same mount. So it should be easy to get the proper piece to adapt to your truck.
__________________
Dave F
1989 F250 XLT Diesel
  #3 (permalink)
Old 11-11-2010, 08:15 AM
Thanks for the info I will be working on it this Saturday first taking the plow off and then I will try the lift into place and block method and fab from there thankyou for the info.by the way assume picture of a working blower.watching the picture it looks like the belt might even be slipping a little a those tremendous rpms
Tags
1986, 1990, 90, 97, attachment, f150, f250, fit, ford, gmc, meyer, meyers, mount, plow, plowmount, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
