Leveling kit and 35"s????
I hope I don't have too many issues with rubbing... I'll be installing X-codes and 2" leveling kit in another week here. (Plus dual stabilizers and adj. Trac-Bar. )
I have a set of Goodyear DuraTracs on 16x10" wheels.... I know it's going to be close, them are some wide tires!
That chrome cap on the rear hub... did the rims come with it, or did you buy that?
It might rub the back of the inner fender. Nothing you will have to change. At least mine is ok. With stock wheels, you will probably rub the leafs. But you are right, mine are quite wide haha
Those are Mickey Thompson Center Caps. They came with my wheels but i am pretty sure you can buy them separate. Summit Racing has a few different caps. Not sure if they have the MT ones or not. I use Procomp ones on my black steel winter wheels. They are plastic and the ends pop off. The MT ones are steel.
My stock 4,800lb springs are right flat.
These X-codes should firm it up quite a bit and lift it a couple inches. It's 4.5" lower than the rear on the passenger side, 4" lower than the rear on the driver's side.
Mine is set up with spring packs in the front and running 37x12.50x17's on the ford OEM later model wheels. The PO set it up this way , but I love the way it looks and it still (just) fits in the garage.
The inner fender plastic is trimmed and held back with some zip ties, the tries do rub the spring on the drivers side front of the axle only when at full lock.
If all your doing is street/hwy driving its not a bother, IMHO.
Cause the chicks dig it!
Ace!
1999 to 2016 Super Duty
23
07-30-2016 10:25 AM
