1976 F250 Wiring diagram - Ford Truck Enthusiasts Forums
Old 11-10-2010, 06:15 AM
1976HighBoy's Avatar
1976HighBoy 1976HighBoy is offline
1976HighBoy is starting off with a positive reputation.
Hello friends, anyone know where I can get a wiring diagram for my 1976 F-250, I have some electrical work that needs straightening out and the tech who is doing the work refuses to lift a finger until I get him that manual.
Old 11-10-2010, 08:51 AM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
What exactly is wrong ? The wiring is simple in these trucks.
Old 11-10-2010, 10:25 AM
When I apply the brake the right blinker in my instrument cluster lights up and stays on until I let off the brake. When I do brake if I am making a left hand turn the blinker on the outside of the truck stops blinking until I let off the brake. The left tail light brake light will not light up unless the brake is pressed extremely hard. Yes I have check and replaced brake switch, replaced all tail light sockets, and cleaned and checked all grounds. I was told there was a ground problem in the column most likely. I know sometimes when I am making a turn that one or both of the blinkers will flash. I need a new cam or what ever makes my blinkers return after making an actual turn. I realize the wiring on these trucks are pretty basic, but the tech I am taking the truck to wants to know a exactly how the wiring harness and wiring in the column should be. I have taken the truck to 4 ASE certified master mechanics and none of them could even come close to figuring the problem. This new fellow is suppose to be the best automotive wiring tech around, at $100 dollars an hour he Damn well should be!!!!!!!
Old 11-10-2010, 10:52 AM
tinaheels's Avatar
tinaheels tinaheels is offline
tinaheels is starting off with a positive reputation.
sounds like turn signal switch is messed up
Spark plug wire set for 1976 F150 360 cid 1976F1504X4360 1973 - 1979 F-100 & Larger F-Series Trucks 4 09-19-2016 06:00 PM
1976 F100 Gauge Cluster klansing 1973 - 1979 F-100 & Larger F-Series Trucks 2 10-18-2014 10:58 AM
fuse box diagram 1976 F250 2-door extended cab chrismcnair1512 1973 - 1979 F-100 & Larger F-Series Trucks 0 11-17-2012 11:23 AM
1976 F250 Auxiliary Battery Questions 23racer 1973 - 1979 F-100 & Larger F-Series Trucks 5 07-24-2012 10:45 AM
Wiring diagram for a 1976 Highboy?? forddude55 1973 - 1979 F-100 & Larger F-Series Trucks 2 04-11-2012 06:32 PM
Tags
1976, 250, 76, 79, ac, diagram, diagrams, f250, ford, harness, radio, series, truck, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
