I am getting ready to install Sinister EGR full delete kit. I am wanting to know who is the best for getting custom tune wrote and what kind of cost is it? Any other info for the install of the Sinister kit would be helpful.
I used the RCD Egr delete kit, Josh did a custom tune for me with a SCT tuner. I am very happy with the SCT tuner. I did have an Edge tuner, but I am more Happy with the SCT tune. Seems like I notice more of a power change when I change tunes with the SCT than Edge.
I have Innavative deisel tunes with the stock EGR junk still there. I wanted to turn the EGR off at least, I will do the delete kit at the same time as head bolts & turbo.
I finished the EGR delete not to bad of a job. I also cleaned turbo while it was off. Everything was pretty good other than I noticed oil in both of my intercooler tubes is this normal? Iam not sure what to do I had oil cooler replaced 6,000 miles ago while it was still under warranty. It is 05 F250
... Everything was pretty good other than I noticed oil in both of my intercooler tubes is this normal? Iam not sure what to do I had oil cooler replaced 6,000 miles ago while it was still under warranty. It is 05 F250
Simply, Yes. The CCV (crank case vent) is routed right back into the intake and on through. Do a search on CCV Mod and you will see.
Clean boots real good, then spray a little hair spray on the connecting points and install clamp. Helps prevent blowing off the tubes.
