Expedition 2003 Flasher Problem - Ford Truck Enthusiasts Forums
Old 11-09-2010, 04:37 PM
Kingstyle01 Kingstyle01 is offline
Kingstyle01 is starting off with a positive reputation.
Ok my turn signals stopped working as I was driving.
Checked the fuse, its ok, Swapped the flasher unit out after finding it under the steering column. Changed the multi function switch! Still no turn signals??? The Hazards do still work though.
Does anyone know what this might be? Many thanks
Old 11-09-2010, 09:23 PM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Are you sure you found the correct flasher? This picture shows a flasher relay in a aux relay box more toward the driver's side kick panel.
AutoZone.com Repair Guide Image)
This wiring diagram also shows it in aux relay box #3.
Old 11-10-2010, 07:46 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
There are two fuses that are used in the turn signal circuit:
F2 in the CJB is needed for both hazard and turn signal operation. It is ALWAYS HOT circuit.
F18 in the CJB is needed for the turn signals and is a HOT IN START OR RUN. If this fuse is blown or its power is otherwise not reaching the flasher module, you will have hazards but no turn signals.
Check F18 as I suspect you only checked F2.
Old 11-10-2010, 04:00 PM
Thanks guys! I did have the correct Flasher Unit location, but I see that actually! TWO fuses control the flasher. Guess what! I checked the second fuse and it had blown! Wish I had come here first!
Thank you so much for the Diagram. Happy man in Florida now
Old 02-19-2014, 03:35 PM
WA8IQO WA8IQO is offline
WA8IQO is starting off with a positive reputation.
Having the same issue but have discovered an additional problem
Hi everyone - Came across this old posting via a google search. I too am having the same issue but have discovered an additional problem.
I too have no active right and left turn signal with working hazards.
I have a late production 01 (01 1/2) Expedition and not a 03 as original discussed.
I had intermittent working signals that were based on the amount of pressure that was applied to the switch/lever on the steering column. I replaced the turn signal switch/lever thinking this was the problem. Now that the new one is in, I still have no signals but now I have a working rear wiper that I didn't have before. I fixed a issue that I didnt mean to fix because I never my rear wiper, but ok...
Then I replaced the signal relay. I found it next to the hazard relay as discussed in the post. Still nothing...
I have check both F2 and F18 fuses as recommended and they were found to be good. However, F18 appears to have no power on either side of the terminal. I check it using a small 12v test light in the: On, Run and Start position. Nothing... I testing it thinking it was a HOT (+) circuit.
According to my user manual F18 also controls the dash light dimmer function which is working just fine. I remove the fuse and it still works fine. So, that leads me to believe that maybe the 01 and 03 are not the same?
So, with that being said I'm looking for additional troubleshooting suggestions.
Thanks
No turn signals 51camohunter 1987 - 1996 F150 & Larger F-Series Trucks 15 06-30-2016 12:02 PM
Turn signal problem Bradley Ripley 1999 to 2016 Super Duty 1 02-22-2016 11:51 PM
F800 Dump Truck Turn Signals skd91 Large Truck 6 10-31-2015 10:34 PM
1993 E350 7.5 L - Flashers E30tdf Electrical Systems/Wiring 4 05-17-2014 01:55 AM
Turn Signal Flasher Problem speedyweasel 1997-2006 Expedition & Navigator 1 10-16-2012 10:33 AM
Tags
2001, 2003, 3, auxillary, box, expedition, explorer, flasher, ford, location, module, realy, signals, truck, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
