Radiator question
Old 11-11-2010, 06:51 PM
whateg01's Avatar
whateg01
whateg01 is offline
I'm not sure a stock radiator would have enough capacity to cool a bigger motor. Maybe a repro that looks like a stock radiator, but has more capacity? That might cost more, though.
Dave
Old 11-11-2010, 06:54 PM
carnut122's Avatar
carnut122
carnut122 is offline
Originally Posted by BBKtech2
I'm a purist. Stock radiator. I think it was Griffin that has an aluminum version of the stock radiator. Looks great. Copper is just fine though. Above all else, it has to have a shroud on it to perform at it's best. 16 -18" fan.
Can you run a 15 lb cap on those?
Old 11-11-2010, 07:11 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,410 Likes on 1,370 Posts
The stock radiator has plenty of capacity to cool a normal small block Ford or Chevrolet. Probably even a Mopar, too. I used the original 6 cylinder rad with my 289 in my 50 and it worked perfectly, even with the stock 4 lb. cap. It's about twice as big as the one found in a Mustang with the same engine combo. The only modification I made was to the upper water neck. I had it come out straight (90 degrees) from the top tank, as opposed to the down angle as original for better hose to fan clearance.
If you want to run a pressure cap, like a 15lb., I would go with a new, aftermarket replacement that's designed for that purpose. No sense taking a chance on busting a seam on an old rad not made for such pressures. Those kind of things only happen at the worst possible time.
Old 11-11-2010, 08:05 PM
husker's Avatar
husker
husker is offline
I had been running a stock radiator in mine with a 460, but it'll heat up on a hot day or when idling around. I don't have a shroud and that would probably help a bunch.
The truck is torn apart now to do body work etc. I'll probably try to find a different radiator when I get it running again to eliminate some over heating. Also, I'm adding airconditioning, so will need more capacity with the condenser up front.
Old 11-11-2010, 11:52 PM
t900enforcer's Avatar
t900enforcer
t900enforcer is offline
We have stock radiator with a SB350 in our 55 and it has no problem keeping it cool. It was a fairly easy install but we do have an ABS shroud that we bought from Mid-fifty.
T900
Old 11-12-2010, 09:27 AM
BBKtech2's Avatar
BBKtech2
BBKtech2 is offline
I would stay with a 7-9 lbs cap on a stock radiator. Good flex fan, shroud and 180 degree thermostat. Cool runnin'
Old 11-12-2010, 12:16 PM
Moe Craig's Avatar
Moe Craig
Moe Craig is offline
In Tempe, AZ I had a stock radiator (home made shroud) and external trany cooler in my 49 f1 with a '66 425 Super Rocket V8 / T-400 combo behind it didn't overheat... a few years after I pulled it out when I was working at a radiator shop and took it apart and cleaned it... no problems used it that way for about 5 years until I had a brain fArT and sold the truck... Wish I could find it again, hard to give up your first love....
BGF100
07-24-2017 04:04 AM
hardy53
09-16-2015 08:03 PM
chappys4life
04-01-2012 04:09 PM
HT32BSX115
16
12-24-2009 03:55 PM
linckeil
09-12-2009 11:02 PM
Quick Reply: Radiator question
