97 f150 swapping a 5.4l to a 5.8 (351) - Page 9 - Ford Truck Enthusiasts Forums
View Poll Results: what motor would you choose for the ultimate trail truck?
302 4 21.05%
5.4l 8 42.11%
5.8l 6 31.58%
4.6l 1 5.26%
Voters: 19. You may not vote on this poll
  #121
Old 04-19-2011, 08:57 PM
alpha/omega's Avatar
alpha/omega alpha/omega is offline
alpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to all
^^^ werd
<fiiiill>
  #122
Old 01-04-2012, 10:57 PM
dixie_mwbb dixie_mwbb is offline
dixie_mwbb is starting off with a positive reputation.
back again
So here we are a year later darn near and I am proud to say the swap is done boys. 5.8l efi ripped apart and carbed out. Took a lot on the timing but got her to turn over. I have a c6 behind her. I had to fab up some motor mounts. To easy. Tranny was almost compattible with original e40d. Had to fab up some extension type brackets for tranny for extra support. Biggest issue so far has been fuel. Original fuel pump pushes 95 psi from tank...way to much for a regulator. It blows right through. Put an inline electric on rail but it wouldn't pump enough through original pump. So regardles...old pump got the boot and now I have perfect fuel ratio. Still have to hardwire alternator figure out poer steering pump a throttl cable build some tranny lines and have drive shafts extended and yoke changed. Will be using a manual cable to lock in four by on the front diff. Will be postingpics and video of first fire in the next few days. So.....ya it can be done. A lot of work but plausible.
Dixie
  #123
Old 01-05-2012, 10:34 AM
Shouldve bought an Aeromotive A1000 regulator. It will handle it
  #124
Old 01-05-2012, 10:56 AM
Lol ya..looks like it
  #125
Old 01-05-2012, 01:06 PM
or better yet, maybe you shouldve checked in over the past year for some suggestions. :flip:
  #126
Old 01-05-2012, 01:23 PM
Well she's been sittng. New years eve floated around and we kinda just jumped into it. Deployment time kinda put a halt on progress or commo. Regardless I'm pretty excited. Should be on the road in a month or two
Motor swap from a auto xl 93 5.0l to 94 5.8l FordDylan 1987 - 1996 F150 & Larger F-Series Trucks 5 10-17-2015 05:07 PM
EV1 Injector Revamp and Install Evan_P 1987 - 1996 F150 & Larger F-Series Trucks 2 06-07-2013 09:10 PM
Why don't we use (Cubic Inches) anymore? 640 CI Aluminum FORD 2009 - 2014 F150 57 03-05-2012 01:22 PM
mod's to 97 f150...dropping 351 in...mud bogger dixie_mwbb 1997 - 2003 F150 11 01-11-2012 01:17 PM
Ford 5.8L (351) to 5.0L (302) engine swap Silvereagle 1987 - 1996 F150 & Larger F-Series Trucks 8 03-21-2011 12:44 PM
Tags
351, 54, 54l, 58, 58l, 97, bore, conversion, f150, ford, liter, motorswap, swap, swapping, triton
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
