97 f150 swapping a 5.4l to a 5.8 (351) - Page 4 - Ford Truck Enthusiasts Forums
View Poll Results: what motor would you choose for the ultimate trail truck?
302 4 21.05%
5.4l 8 42.11%
5.8l 6 31.58%
4.6l 1 5.26%
Voters: 19. You may not vote on this poll
  #46
Old 12-23-2010, 11:35 AM
captain p4's Avatar
captain p4 captain p4 is offline
captain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud of
plus 6 hundred and thirty two.
  #47
Old 12-27-2010, 04:06 PM
dixie_mwbb dixie_mwbb is offline
dixie_mwbb is starting off with a positive reputation.
custom aluminum dashboards...any one know a good company that sells them? let me know.
  #48
Old 12-27-2010, 04:23 PM
fatdan460 fatdan460 is offline
fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.
theres a company called doityerself that does, and conveniently enough, they work right in your garage
  #49
Old 12-27-2010, 04:37 PM
lol, ya i deal with them alot. i have never worked with anything like this, and am researching right now what kind of tools i would need to do this on my own. i am assuming if i get a thin sheet i can do all the cutting with tin snips, and bending with like a wood block and a hammer? i would have to tke it in to get welded, but i am sure i can take it to the muffler shop and get some tachs done. is there any tools i can purchase that would help in this project or is it as simple as i am thinking
  #50
Old 12-27-2010, 04:45 PM
to do it at home the backyard fab way a bunch of different style clamps and a good vise are a starting point. a nice thick wood or steel shop table with a solid square top and edges works for bend forming flat thin plate, just clamp the flat stock to the table and slowly bend it over the edge. as to cutting, it all depends on tools and time involved. tin snips could work, but an air cutter(don't know the real name, hope you know what i mean) or an angle grinder with a cutoff wheel would make it quicker.
as to welding it up, you might have to hit up a local welding or fab shop. i don't know if the local muffler shop would be able to pull off nice clean tig welds on thin aluminium.
  #51
Old 12-27-2010, 05:02 PM
77mud's Avatar
77mud 77mud is online now
77mud has a good reputation on FTE.77mud has a good reputation on FTE.77mud has a good reputation on FTE.
Quote:
Never thought id say this but Dan FTW! LOL + reps!
  #52
Old 12-27-2010, 05:15 PM
thanks dan, i will be giving it a shot next week i think
  #53
Old 12-27-2010, 05:35 PM
Quote:
thanks larry
Quote:
and be sure to get some pics for us. pics=good
  #54
Old 12-27-2010, 10:57 PM
alright so..big question is...aluminum or sheet metal?
  #55
Old 12-28-2010, 12:03 AM
if the welding is a big concern, or you plan to paint it i'd go with sheet steel. otherwise aluminium, diamond plate and old flattened out empty beer cans both bring a different sort of "classiness" to the cab
  #56
Old 12-28-2010, 02:25 AM
hav24wheel's Avatar
hav24wheel hav24wheel is online now
hav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputation
I have never seen a muffler shop that can weld aluminum.
Aluminized exhaust pipe is welded just like mild steel.
I'd say sheet metal of the steel variety is ur best bet. Don't need special cutting wheel/sanding/grinding disks for it.
  #57
Old 12-28-2010, 06:37 AM
77mud's Avatar
Agreed!...
  #58
Old 12-28-2010, 11:58 AM
ya agreed, will take some pics and keep everyone posted throughout this process. i am working the cab first, then once the truck is done and have all the electrical kinks worked out to work with the carb and not the efi, ill build up the motor. i have the wiring harness still in there with the 5.4 computer. but worried fi remove the entire wiring harness ill loose all the interior lights, headlights, brakes, etc. i am thinking i might rewire them all myself, but would rather not to be quite honest. so that step one. new dash, new gauges and the wiring.
  #59
Old 12-28-2010, 05:45 PM
new questions..need some links to some info pertaining to wiring harness removal. if i take out the entire wiring harness, i loose all power to everything. is there a way to do this , or a step by step online somewhere. cant find a forum on it yet. i can just take each wire i need, i.e. blinkers and head lights, run them about a foot or two back and cut the wires and run them manually up. but is there a way to remove the most of the harness and keep the basics like main power to the headlights, brake lights, interior lights speakers, etc. i dont do electronics very well, and of coarse at first glance it seems impossible. but istarted tracing some wires and i figure if i just cut open the harness and keep my basic wiring, could this work?
  #60
Old 12-28-2010, 07:20 PM
77mud's Avatar
Yup there is a way..... grab and yank
Motor swap from a auto xl 93 5.0l to 94 5.8l FordDylan 1987 - 1996 F150 & Larger F-Series Trucks 5 10-17-2015 05:07 PM
EV1 Injector Revamp and Install Evan_P 1987 - 1996 F150 & Larger F-Series Trucks 2 06-07-2013 09:10 PM
Why don't we use (Cubic Inches) anymore? 640 CI Aluminum FORD 2009 - 2014 F150 57 03-05-2012 01:22 PM
mod's to 97 f150...dropping 351 in...mud bogger dixie_mwbb 1997 - 2003 F150 11 01-11-2012 01:17 PM
Ford 5.8L (351) to 5.0L (302) engine swap Silvereagle 1987 - 1996 F150 & Larger F-Series Trucks 8 03-21-2011 12:44 PM
Tags
351, 54, 54l, 58, 58l, 97, bore, conversion, f150, ford, liter, motorswap, swap, swapping, triton
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
