97 f150 swapping a 5.4l to a 5.8 (351) - Page 3 - Ford Truck Enthusiasts Forums
View Poll Results: what motor would you choose for the ultimate trail truck?
302 4 21.05%
5.4l 8 42.11%
5.8l 6 31.58%
4.6l 1 5.26%
Voters: 19. You may not vote on this poll
  #31
Old 11-11-2010, 08:11 PM
alpha/omega's Avatar
alpha/omega alpha/omega is offline
alpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to all
Quote:
Originally Posted by fatdan460 View Post
every a.hole in sight has a mustang with something done to it, they must like to pay high prices.
I think thats why valve covers are $400.
  #32
Old 11-11-2010, 09:59 PM
captain p4's Avatar
captain p4 captain p4 is offline
captain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud of
At a minimum there are two cams for the mod motors, worst case there are four. Hence the high cost for cams.
  #33
Old 11-29-2010, 12:27 PM
dixie_mwbb dixie_mwbb is offline
dixie_mwbb is starting off with a positive reputation.
i have the 351w with a c6 transmisison in my garage to go behind it. I have the computer for the Windsor as well. I wiould like to go carberated but at a different time perhaps ( when money permits it, one project at a time) i know i will need to move the cross member and the motor mounts...anyone else see any other problems with this?
  #34
Old 12-11-2010, 08:36 PM
im pretty sure a trombone was a brass instrument, lol...so there would be no reed. but anywho. I have found a 5.8l v8, i stripped all the efi crap off of it, intake everything. Swithing it back to an original 351w. All i am missing now is a carberater. i am going to try and run the same distributer on it but i dont know if that will work, i also found a c6 transmission that i am going to be putting behind it. Due to my torsion bars in the way, maneuvering the old tranny out is somewhat of a major pain. My cross member will still work to mount the tranny, i just have to drill some new holes where it will mount and wham bam thank you ma'am that should do it. I will have to put a hole in the floor board for the new stick to tgo through , that changes the 4 by gears. i know i need some new motor mounts, and the splines on the drive shaft dont match up, but thats an easy fix. dont know if they are going ot be to long or too short yet, but we will see once i get the tranny in there. if any one has any input on this project yet, let me know.
  #35
Old 12-20-2010, 09:08 PM
got the 5.4 out and am now trying to figure out what i am going to do about these motormounts, the 5.4 are horizontal and the 5.8 are vertical. so looks like i am heading to a junk yard soon to get the bracket
  #36
Old 12-21-2010, 01:27 AM
ford005's Avatar
ford005 ford005 is offline
ford005 is gaining momentum as a positive member of FTE.
IMO the 5.8 is the way to go. A BB would be best if it were a mud truck, that's for sure, LOL!
I would keep it EFI as it should be easy to adapt (return style fuel system) and the ecu's aren't all that hard to wire up, especially since you have it. I don't know what the mounts look like in the F150, but the SD and Excursions had a mount that looks similar to the van mounts: two vertical studs. I would probably make my own, either using a bushing in dom and making the stand off and a plate to bolt to the engine, or use mustang 5.0 convertible mounts (or after market, the fully captured style) and make the frame side mount.
Good luck and I look forward to some pictures!
  #37
Old 12-21-2010, 11:13 AM
ya i might look into building my own brackets somehow, seems like it would be the easiest route right now.
  #38
Old 12-21-2010, 12:06 PM
I dont remember this build and Im too lazy to look back...
Why exactly are you wanting to put a 351w in place of a 5.4?
  #39
Old 12-21-2010, 12:33 PM
two reasons really. number one, i got this 5.8 for free from my brother in law, and was able to trade out the blown 5.4 for all the parts i need to carb it out. I am all about originality in my truck club, and i have yet to see a 97 with a 5.8 in it. (351W) also the 5.8 gets more power, and the c6 tranny is built a lot better,
  #40
Old 12-21-2010, 01:02 PM
77mud's Avatar
77mud 77mud is offline
77mud has a very good reputation on FTE.77mud has a very good reputation on FTE.77mud has a very good reputation on FTE.
sorry but a 5.4 makes more power than the 5.8 ever dreamed of torque wise aswell
  #41
Old 12-21-2010, 05:45 PM
well, we will see, i know the DOC was nice and you could build it up, but i bought this truck with like 199k on it, there was problem after problem, and even though i was still the fastest through the pits, i just didnt get that feeling you know. i used to have a 5.8 in a 94 and that truck felt way beefier. i dont know much about anything, i am a rookie at all this motor stuff. But the 5.8 was complete and free, andi needed a new motor. So thats what i went with. i could have rebuilt everything and put some new cams in it, but for time and money this kinda seemed like my route. one day when i make more ( get out the army, lol) ill probably through a beefed up 5.4 in it.
  #42
Old 12-21-2010, 06:44 PM
+1 vote for this truck never running under its own power again...
  #43
Old 12-21-2010, 07:17 PM
ya your going to have to rephrase that one for me. lol i dont get it.
  #44
Old 12-21-2010, 07:26 PM
77mud's Avatar
he starting a tally for 'this truck will never move under its own power again'
  #45
Old 12-21-2010, 07:53 PM
ya im retarded i get it now, well hopefully it will i will keep you posted.
Motor swap from a auto xl 93 5.0l to 94 5.8l FordDylan 1987 - 1996 F150 & Larger F-Series Trucks 5 10-17-2015 05:07 PM
EV1 Injector Revamp and Install Evan_P 1987 - 1996 F150 & Larger F-Series Trucks 2 06-07-2013 09:10 PM
Why don't we use (Cubic Inches) anymore? 640 CI Aluminum FORD 2009 - 2014 F150 57 03-05-2012 01:22 PM
mod's to 97 f150...dropping 351 in...mud bogger dixie_mwbb 1997 - 2003 F150 11 01-11-2012 01:17 PM
Ford 5.8L (351) to 5.0L (302) engine swap Silvereagle 1987 - 1996 F150 & Larger F-Series Trucks 8 03-21-2011 12:44 PM
Tags
351, 54, 54l, 58, 58l, 97, bore, conversion, f150, ford, liter, motorswap, swap, swapping, triton
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
