Go Back   Ford Truck Enthusiasts Forums > Misc. > Aftermarket Products
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Aftermarket Products SPONSORED BY:
  #1 (permalink)
Old 11-09-2010, 02:02 PM
b-uno's Avatar
b-uno b-uno is offline
Rep spread Extraordinaire
Garage is empty, add now
b-uno has a superb reputationb-uno has a superb reputationb-uno has a superb reputationb-uno has a superb reputationb-uno has a superb reputationb-uno has a superb reputationb-uno has a superb reputationb-uno has a superb reputationb-uno has a superb reputationb-uno has a superb reputationb-uno has a superb reputation
greythorn3
Question Aftermarket HID kits safe for street use?
We were having a heated debate on the safety on non-OEM hid kits that are not DOT approved.. like the kits you would find on ebay or craigslist..
What are you all's feeling on the HID lighting retrofit kits people can buy? are they safe? have you been blinded by a ricer with the kit that didnt know how to put in a sparkplug let alone adjust a headlight?
Or have you had great experiances with aftermarket hid
__________________
-=Skip=- 2000 Excursion limited 4x4 7.3 4R100 oil and filter 203300 miles air filter 196000 fuel filter 4/14/2013 212221 Miles alternator 1/30/2012 199226 miles. Lifetime member of the Semper FI country club.
  #2 (permalink)
Old 11-09-2010, 05:14 PM
b-uno's Avatar
greythorn3
from a law enforcement forumn
"NHTSA has threatened to fine sellers of "HID conversion kits" $10,000 per kit sold. You CANNOT install a HID bulb in a headlight designed for a halogen bulb. There is no way you can control the light output properly and you end up blinding oncoming cars and you cannot see properly yourself. Read the fine print on some of these websites selling them..not legal for on-road use....where else do you use a car? They are an illegal & unsafe install."
__________________
  #3 (permalink)
Old 11-09-2010, 05:21 PM
Old93junk's Avatar
Old93junk Old93junk is online now
Old, tired and grouchy
1993 Ford F-250
Old93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputation
Illegal EBAY and CL HID kits are dangerous garbage! They do little more than blind oncoming drivers when used in the enclosures meant for std. halogen lights
If you are going to do HID, do it right and get HID specific enclosures. There is a reason they are illegal.
I have barely contained myself from doing a 180, and running down one idiot with these BS lights.
__________________
93 F-250HD SC 460 E4OD
96 Explorer Limited 4.0 V-6 OHV
93 Ranger Splash 2.3 5spd only 51,000 miles!
84 Ranger 4x4 2.8 V-6 5spd......450,000 miles, now on a brand new 2.8
Dave
Oregon Assistant Chapter leader: To join the Oregon Chapter, click HERE
  #4 (permalink)
Old 11-09-2010, 05:26 PM
b-uno's Avatar
greythorn3
I agree anymore, i just steer into the light, cause i cant see a damn thing, so if im gonna die so are they! adn if we live I will let a court of law decide why i couldnt see to drive. when they inspect the offenders headlamps after the accident.
__________________
  #5 (permalink)
Old 11-09-2010, 05:38 PM
Old93junk's Avatar
1993 Ford F-250
If you look at some high end import like a mercedes with stock HIDs in HID specific enclosures, you will NOT be blinded by them anymore than std. incandescent.....
Put these BS kits in standard halogen enclosures, and it a recipe for causing a bad accident or having someone follow you and kick your azz!
Standard halogen type headlight enclosures diffuse and aim the HID light incorrectly, causing grief for everyone else on the road......just ask a truck driver what its like encountering these things.
__________________
Dave
  #6 (permalink)
Old 11-10-2010, 06:55 PM
ReAX's Avatar
ReAX ReAX is offline
2002 Ford F-250
ReAX is a name known to allReAX is a name known to allReAX is a name known to allReAX is a name known to allReAX is a name known to allReAX is a name known to all
I've been on that kick for a few years now. HID lamps give off light in a different plane, incandescent lamp reflectors are deigned around the bulbs filament and cast a different pattern. With modern head lamp assy's the focus of the beam is all set by the reflector and no longer by the lens, so changing the orientation of the light modifies the pattern.
It's going to end up just like the all clear tail lights from 10 years ago. Someone will come up with a HID conversion that fits into NHTSA's rule book once they start handing out fines.
__________________
Too many mods to list, so click here.
Here are my tech write ups
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
  #7 (permalink)
Old 11-11-2010, 04:04 PM
walt501 walt501 is offline
walt501 is starting off with a positive reputation.
Well over the past couple of weeks I've read all the treads I could find on increasing the light output in the Super Duty/Excursion line. Everything from higher wattage bulbs to installing HID's in the stock headlight housing and even installing projector HID's in a modified headlight housing. I have to say that the projector beam in the modified housing had a very clear light pattern cut-off. This person went to great pains to come up with a solution that would improve their vehicle lighting without blinding oncoming drivers. I would really like to see one of the after market truck vendors come up with a projector beam in a modified headlight housing - for off road use only, of course. There has just got to be a way to improve our night driving without concern for oncoming traffic.
  #8 (permalink)
Old 11-11-2010, 11:07 PM
b-uno's Avatar
greythorn3
Quote:
heck ya im all for brighter lights as long as they are not blinding people. thats why i would just use the stock lights, then have some hid aftermarkets on a switch when there is no other cars around.. i think thats the best idea.
__________________
  #9 (permalink)
Old 12-01-2010, 10:52 AM
freerider freerider is offline
freerider is starting off with a positive reputation.
Time for me to chime in....as I have tried a few different options in my '07 expy as I was super unsatisfied with the light output on Hi beams!
I tried:
-Silverstar Nighthawks bulbs: decent light on low, but still crappy on high beams.
-PIAA Extreme White bulbs: the blue tint of the lens made the colors wash out on the road...especially the bambi's!
And then, I tried an aftermarket HID kit that went in the reflector housing. (I can hear the grumblings now... ...) I'd like to point out that they were actually not as glaring as you would think (atleast for the Expedition! I agree that other kits are awful). I aimed the lights into the proper position and tested the glare out by having my wife drive the truck while I drove the van...even had a friend do the same and it was concluded that there was, luckily, no glare. BUT! The light being reflected to the ground was horrible. My night vision was completely ruined because of how much stray light was being reflected onto the pavement right in-front of the truck. When I went to Hi Beams, it was still just as bad as before. I concluded that it was the crappy reflector design.
Would I recommend the HID upgrade: HELLS NO! The reflector is not designed for the high intensity of the light! The bulbs ARE the exact same size, but clearly the light output is not.
And here was the next step….and start of an epic fail!!!!
I ordered up a set of Eagle Eyes Halo/Angel Eye Projector headlights…these were about $300 for the pair. The original bulbs in them were Halogens with separate Hi and Lo Beam bulbs (H1 and H7). The way the wiring harness splits the leads, when the Hi Beams are selected, the Lo beams go out…. Not bad for Halogen, but totally scary when I put the HID bulbs in!!!
The other major concern was the beam pattern of the projector. There was no light going to the sides because of an even crappier design! Here is a link to my album showing this mod:
Ford Truck Enthusiasts Forums - freerider's Album: Projector Headlight Assembley with Angel Eyes - FAIL
The lights look very cool, and are OK in the city and decently lit areas. But on the Highway, in the middle of Timbuktu, THESE ARE A MOJOR SAFETY CONCERN! DO NOT BUY!!!!
I am currently awaiting a “real” set of projectors from The Retrofit Source which will actually mount in my existing OEM reflectors. These projectors and HID’s are the same as from Lexus and BWM and will provide DOT approved light! The only hinge is that I have to remove the lens cover from the OEM assembly and then get it back on… there are tons of write up on how to do it and it is the only safe modification I would recommend.
  #10 (permalink)
Old 12-01-2010, 02:40 PM
b-uno's Avatar
greythorn3
interesting! and some real world testing! good info. i was thinking about trying some but i dont want no worse night vision.
__________________
  #11 (permalink)
Old 12-25-2010, 01:25 AM
ganzey ganzey is offline
ganzey is starting off with a positive reputation.
actually i had no problem with them. when i installed them i closed my garage door and noticed they pointed up more than the stock halogens, so i aimed them down. i could see good and they didnt blind people(i know because i drove by it in my bro's truck to make sure they wouldnt)
  #12 (permalink)
Old 12-25-2010, 08:09 AM
97flairside 97flairside is offline
97flairside is starting off with a positive reputation.
only street legal hids that were available were the Sylvania Xenarc hid's. They were available for ford and chevy as full headlight housing replacements. I had them on my 97 and currently still have them on my 98.
  #13 (permalink)
Old 12-25-2010, 09:58 AM
WarOzz's Avatar
WarOzz WarOzz is offline
1992 Ford F-250
My Garage
WarOzz is gaining momentum as a positive member of FTE.
subscribing... will chime in later.
__________________
Ed - Lincoln City, Oregon - Oregon Chapter Member | Join Our Chapter Here
Machinist/Programmer - Jim Meyer Racing Products
1992 F250 S-Cab 4wd 7.3L IDI ZF5 - Straight Pipe, Ram Air, IP Turned Up, Bi-Xenon 6k HID Lights in Clear Euro Lenses.
1975 F250 Camper Special - Soon To Be Transformed!
  #14 (permalink)
Old 12-29-2010, 10:35 PM
BullyDogJason BullyDogJason is offline
SPONSOR
BullyDogJason is starting off with a positive reputation.
hids on factory fords are horrible for scattering light.
projectors are a must
__________________
1-886-285-5936
www.bullydog.com
  #15 (permalink)
Old 12-29-2010, 10:36 PM
b-uno's Avatar
greythorn3
probably safer to drink and drive and have just you impaired then to install a hid kit and impair everyone in oncomming traffic.
__________________
Tags
1978, aftermarket, bronco, clear, deleware, ford, hid, improving, inspection, kits, light, maryland, massachusetts, output, raptor, sold, yearly
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
