radiator for a 94 POWERSTROKE - Ford Truck Enthusiasts Forums
Old 11-09-2010, 10:37 AM
RRranch RRranch is offline
RRranch is gaining momentum as a positive member of FTE.RRranch is gaining momentum as a positive member of FTE.
anyone got the proper part number for the correct all metal 4 ROW radiator for a 94 powerstroke? I took mine to get rodded out, they said it was trashed so ordered me a new one from ready rad. a 432194. I get it in and it's a 3 row. That's not going to work. I looked it up and the company that made it says it's a 4 row. It's got the right part numbers but I guess they smoked some crack the day it was boxed.
Old 11-09-2010, 10:42 AM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
Yeah, I found another leak on mine, I'm going to need one too.
Old 11-09-2010, 11:05 AM
Hey, does your upper rad hose go in by the cap or on the other side? I could have sworn mine was on the left side. This new one isn't. I'm all screwed up now because I put my 97 radiator and degas bottle in it when I took the old one to the shop. I think they completely gave me the wrong stuff now. With the right part number though. Go figure.
Old 11-09-2010, 11:27 AM
Talyn's Avatar
mine goes in right in front of the Alternator.
The new style ones are on the side though I believe.
The older style ones like ours are said to be less efficient cause they start from the top.
Old 11-09-2010, 11:39 AM
That's a crock about being less efficient. If you have the original 4 row and it is clean inside then nothing will beat it. I have a brand new big 2 row aluminum piece of crap in mine from the 97 right now and I can not pull my horse trailer with it when I have the camper loaded. With the old one it never cared at all. It never got even close to hot going up mountains. Now I can't even keep it going on a level road without overheating. Copper is a better conductor of heat and the 4 row has almost twice the surface area for heat transfer as the newer ones. Think about it. The newer truck owners just like something to brag about.
Old 11-09-2010, 11:54 AM
Talyn's Avatar
I'll agree to that Ryan.
Copper is better at pulling heat, but aluminum is better at dispersing heat.
Mines scaled up inside, but still does a good job. Could do better while hauling though. And the leaks dont help, they are pinholes thankfully. i don't loose much too quick.
Old 11-09-2010, 12:10 PM
I just called around and got a huge range of prices. The ready rad brand I just got was 309. It's supposed to be a 4 row but isn't. It is copper and brass though.
A radeon I think plastic and aluminum 4 row is 210 my cost. I love the price but not sure about plastic in this truck. It scares me a little with the nightmare radiator I had in my f150. everytime I went 4 wheeling I had to take it back to Ford for a new one because the tanks sprung leaks. This truck is MUCH rougher off road than that one was.
Then there was another brand whos name I forget 4 row all metal for 380.00. wholesale. he said retail on that one was over 500. I am lost. I need a new one this morning though. I have a 40 foot flat bed waiting for me to hook up and load about 10 tons of firewood on. At least 10 tons. I've had 20 on it before.
Old 11-09-2010, 01:56 PM
Talyn's Avatar
I don't like plastic tanks.
Copper and brass for the win, but I'd go for a 4 row again.
Old 11-09-2010, 07:13 PM
plgebbia's Avatar
plgebbia plgebbia is offline
plgebbia has a good reputation on FTE.plgebbia has a good reputation on FTE.
Old 94.5 through early 95 Powerstroke 4 row solid Brass Rad.
Late 95- current style plastic tanks and Alum core
I have had both setups and if the system has no problems and or leaks, both cool very well.
Old 11-10-2010, 02:02 PM
XBAJBUSX's Avatar
XBAJBUSX XBAJBUSX is offline
XBAJBUSX is starting off with a positive reputation.
I had mine replace by a shop the radiator was 360 (oem) and with fluids work came out to close to 500 .just don't forget to add the antifreeze treatment from ford for lubrication I forgot what is called.
Old 11-10-2010, 04:18 PM
helifixer's Avatar
helifixer helifixer is offline
helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.
I have had good luck with performance radiator
https://www.performanceradiator.com/index.php
Radiator part number BainbridgeBrewer 1973 - 1979 F-100 & Larger F-Series Trucks 1 07-13-2016 09:28 AM
Help finding correct radiator -please QuercusRubra 1994.5 - 1997 7.3L Power Stroke Diesel 14 03-02-2015 02:59 AM
Single Row to Double Row Radiator? jdan1993150 1987 - 1996 F150 & Larger F-Series Trucks 27 12-22-2014 05:33 PM
4 row radiator bucks77ford 1973 - 1979 F-100 & Larger F-Series Trucks 4 07-02-2013 11:12 PM
front cover gasket set part number RRranch 1994.5 - 1997 7.3L Power Stroke Diesel 2 12-29-2010 08:42 AM
Tags
1995, 1996, 1997, 94, 95, alluminum, brass, direct, f350, ford, injection, powerstroke, radiator, remove, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
