Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #16 (permalink)
Old 11-09-2010, 02:28 PM
bulletpruf bulletpruf is offline
2003 Ford Excursion
bulletpruf is starting off with a positive reputation.
Quote:
Originally Posted by Nick 99 View Post
When you checked your cables, did you remove both battery and ground cables to check the contact areas? The contact areas need to be clean down to shiny metal and then coated with dialectic (noalox) grease before you reassemble the cables. You might want to check the connection at the starter motor also while the battery cables are disconnected, a bad connection there will cause the same issues. The starter motors on our trucks tend to want to loosen the bolts holding the starter in, so you might want to check the bolts for tightness as well.
I just checked the battery cables at the battery. Will check ground cables and starter connection. Have some dialectric grease that I will use to coat the connections.
Will also check the starter bolts for tightness.
Thanks,
Scott
__________________
2003 Excursion Limited 4x4, 7.3, Harpoon Mod, Hutch Mod, 6637 with Pete's Cover, Baldwin BF1212 Pre-Pump Filter, RS9000XL Ranchos, 285 Michelin LTX AT2s, Warn Hubs, 181k Miles
  #17 (permalink)
Old 11-11-2010, 01:51 AM
carltonwebb's Avatar
carltonwebb carltonwebb is offline
Garage is empty, add now
carltonwebb has a very good reputation on FTE.carltonwebb has a very good reputation on FTE.carltonwebb has a very good reputation on FTE.
It may just be me, but I have had NO luck on non-ford alternators. The ones from the big box stores do not last nor do the ones I have had rebuilt locally. The same local rebuilders can build any other truck or car alternator except the 97 or so and later ones.
Anyone else have problems with the others lasting as long?
  #18 (permalink)
Old 11-11-2010, 06:02 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
1999 Ford F-550
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
http://www.facebook.com/http://facebook.com/Kwikkordead#!/Kwikkordead
That's a tough call.
When I bought my truck with 49,000 miles on it, the factory OE alternator had already been replaced.
I've been installing Bosch rebuilt units on cars for 28 years now and thier track record is very good for me.
I cannot remember the last time one came back on me.
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, Titan 520's, CCV, EGR, CAT.
2000 VW Passat 1.8t Tiptronic. ZZOOOOOMMMM!!!
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
You cannot explain or explain away the power of God.
  #19 (permalink)
Old 11-11-2010, 08:25 AM
USAF CCM's Avatar
USAF CCM USAF CCM is offline
USAF CCM is gaining momentum as a positive member of FTE.USAF CCM is gaining momentum as a positive member of FTE.
Dan,
Where do you get your Bosch remans? Thanks, Les
__________________
Les
2002 True Blue F350 Ext Cab 4x4 7.3 PSD SRW LB
Rhino Line; 4" BDS Lift; Bilstein Shocks; Centerline Rims; Racor Ext Fuel/Enviro Bypass Oil/Magnafine Trans Filters; 8 Autometer Cobalt Gauges; AIS; Toyo 315/75R16 ATs; Banks Monster Exhaust, Mag-Hytec Trans & Rear Diff Covers; BTS; ATS: AIH Delete; Spearco CAC; DP Tuning; DI SS Ups
30 Yr USAF Vet
  #20 (permalink)
Old 11-12-2010, 09:05 AM
1999 Ford F-550
Quote:
Originally Posted by USAF CCM View Post
Dan,
I get them from one of two wholesale warehouses.
I don't know if they have a retail counter or not, but you could ask them.
www.imcparts.net
www.worldpac.com
I think that you will find, however, that PartsGuy Ed will offer a Ford unit for the same cost.
Bosch isn't a cheap knock off part, they are OE suppliers for many of the European vehicles.
__________________
Dan
  #21 (permalink)
Old 11-21-2010, 12:18 PM
2003 Ford Excursion
New alternator is on. Now reading 14V at idle. Good to go (at least until this one dies)!
Thanks,
Scott
__________________
  #22 (permalink)
Old 11-21-2010, 12:55 PM
Nick 99's Avatar
Nick 99 Nick 99 is offline
Nick 99 is gaining momentum as a positive member of FTE.
Can you read the voltage again, but this time put your meter on a/c to read the the alternating current component during the start up so we can get a baseline on a new alternator.
Thanks, Nick
__________________
Sometimes I sits an thinks, an sometimes I jus sits.
  #23 (permalink)
Old 11-22-2010, 06:00 AM
2003 Ford Excursion
Quote:
Thanks,
Scott
Looks like I have the opposite problem now - too much charging voltage! @)#*$)@#*%)!!! Noticed on my drive to work this morning that the battery warning light was lighting up on the dash. However, when I turned the truck off and restarted, it lit off easily. Also noticed that the light wasn't coming on at idle; mainly over 1,200 rpm.
I'll test it again, but looks like I'm headed back to AutoZone for my 3d Duralast Gold alternator in less than a year.
Scott
__________________
Tags
1999, 2004, 46l, 73, 97, 99, alternator, bolts, chargin, charging, f550, ford, low, powerstroke, size, starter, voltage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
