bear claw latch install `55 f100
here`s a few pictures of my bear claw latch install, bought the universal kit from rocky hinge (med size bearclaw) the only tricky part was installing the striker, i wanted to fill the recessed area anyway but the striker nut assy was a bit too thick, i ended up cutting out a rectangular hole into the door jamb so the striker would sit flush, re-inforced the area and made a plate to finish the jamb, nice part with these bear claws you can still use the existing interior handles, they only have to be lenghtened roughly 1/4 inch.
[g]http://wwimw.ford-trucks.com/user_gallery/sizeimage.php?&photoid=236943&.jpg[/img
[img]https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=236939&.jpg[/img
yes its a door opener solenoid, i shaved my door handles, i`ll be installing power windows, i`m almost done installing a one piece window kit, i pulled out my rear door power window mechanism out of my crown vic on the weekend,was comparing them to the trucks original and the gears and travel are the same,arms are different so i`m going to try and adapt the two together, possibly a cheap alternative swap??
Nice job, looking forward to seeing this truck in one piece. FYI for anyone contemplating doing this, Rocky Hinge makes a very nice install kit for these opener/latches, it's a mounting plate with cut out for the latch and has the bolt holes already drilled. It's very sanitary and saves a lot of time. I used them although I put the latches in the door jamb and the striker on the door.
Bear claw latches
Nice job man! I am in the process of adding power actuators to my 56 myself. It was helpfull to see how you used the actuator! btw i purchased my actuators and power window kit from a website www.antonelliink.com they dont have much listed on the site but i called and the prices were reasonable, for what its worth. I hope to get some pics up soon
Awesome!! Great planning. I've worlked with some body guys that said they could install bearclaws, only to have problems when I showed them the track needs clearence. I knew of a guy years ago that did suicide doors on a 56, covered by a magazine and when he got done realized he couldn't mount the front window track anywhere. Opps.
Received 4,132 Likes
on
i never tried the window track on this side of the door, only when i did the passenger side a month ago, the track does not fit at the end of the lock as i previously stated, the track fits on top of the lock assembly, pictures do not show that there is actually room between the track and the solenoid, there is 1/4 inch between them and they do not touch with the track pushed all the way towards the solenoid.
on
