FUEL LINE LEAKING AT FUEL FILTER
HI I HAVE A 2003 F250 2WD 5.4. ALL OF A SUDDEN THE FUEL LINE THAT LEADS INTO THE FILTER IS LEAKING WHEN TRUCK IS RUNNING. I HAVE NOT DONE ANY WORK ON THE TRUCK IN THIS AREA SO ITS ALL A MYSTERY. I NOTICE WHEN LOOKING AT THE FILTER THERE IS A METAL RETAINER CLIP HOLDING THE LINE ON ON THE OUTLET SIDE BUT ON THE INLET SIDE THERE IS NO CLIP AND THE FITTING ON THE LINE IS NOT COVERING THE LITTLE RIB ON THE FILTER ITSELF. WOULD IT JUST COME APART BY ITSELF? ALSO SHOULD THERE BE A CLIP ON THE INLET SIDE?
ANY INFO HELPS-
THANK YOU
ANY INFO HELPS-
THANK YOU
jaspirr
04-18-2010 01:07 PM
92 Red F150
12-06-2009 03:43 PM
Blowinsmoke
09-27-2009 05:18 PM
johnstephens
03-28-2002 04:29 PM
