Thinking about changing manual fuel pump to electric . Any pros or cons . One reason is I am thinking of converting to a wvo dual tank system. It will be alot easier to plumb switchover valves. I know this is not the forum for wvo questions. Just explaining why i am thinking of changing over
I just did electric fuel on mine due to the manuel pump weeping. Throttle is a little more responsive and better top end. In your case I would definently because you can put in a pump that will hold up better to the oil the a factory style pump. Also much cleaner look.
