Front wheels toe out problem.
Just pointin out to the 60 guys that I ain't interested in a debate over it. Nothing wrong with the 60, dam good axle, I just like the 50 and its potential. Sounds like all you need is a front end alignment and bigger tires. Make sure the 35's will clear on the 4 inch lift. Def gonna fill up the front wheel wells. Also start looking for an f350 front driveshaft and tcase yoke incase you develop a vibration in 4wd
coon im glad i could be part of bringing u back, but glad to here ur super busy with work, hard to come by that now a days. and yea the 315's might be tight idk yet, i know im gunna have to trim the front bumper. and the 4 wheel drive seems to wrok fine, i drove 3 hrs in the snow doing any where from 35 to 55. but i do remember some kinda weird noise occaisonally but idk what it was.
well im buying a new winch ready bumper next summer any ways so cutting it seems pretty easy and safe. idk if putting washers in would be easier or compromise safety at all.
So how would one go about finding a GOOD alignment tech/shop without trial/error and wasted $$$?
Make some phone calls and tell them exactly what you want done. They should bring up questions about extra costs of swapping caster camber shims and parts. If the guy tells you you'll be in and out for 59.95 in 20 minutes then you need to go somewhere else. The first alignment after your lift will cost a little more since they will have to change shims.
fastang50
03-28-2023 10:48 AM
bulldogcountry1
03-23-2017 12:26 AM
brock1818
04-03-2016 05:01 PM
ghunt
09-22-2015 11:10 AM
MontanaMan
10-26-2011 06:26 PM
