Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 11-08-2010, 12:53 PM
98explorerltd 98explorerltd is offline
Garage is empty, add now
98explorerltd is starting off with a positive reputation.
Gold Coolant flush
2008 Expy EL, plus 2007 Mountaineer. Both use the Gold Coolant.. Both were bought used after about 20k of intial life. i think lifespan of Gold coolant is about 5 years right?
Thinking about flushing and refilling. I've only previously done this on my old 98 explorer, and it was an all day thing as i drain, refill with water, drain, refill until all the junk was out, and then finally fill with the old green stuff.
Thinking for these two guys, I flush, the just refill, as they are both relatively new, but want to insure that the 50/50 is with distilled. so I would skip the multiple water refilll/drain.
Thoughts?
Thanks.
  #2 (permalink)
Old 11-08-2010, 08:51 PM
gddyup's Avatar
gddyup gddyup is offline
gddyup is gaining momentum as a positive member of FTE.gddyup is gaining momentum as a positive member of FTE.
I just grab my coolant tester. If the coolant freeze point is ok and the sample doesn't look all nasty and sooty, I leave it. If either the freeze point or coolant looks nasty, then I take care of it with a good flush and fill. Coolant testers are your friend and they cost very little cash.
__________________
Firefighter/EMT IAFF Local 4392
"I've done a fair share of stupid things in my life, a couple of which should have put me in my grave. But here I am typing away as if I had a brain." - Craig Wilson
Tags
98, 99, coolant, drain, econoline, expedition, f150, flush, ford, gold, lincoln, navigator, refill, tester, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
