noise/vibration on deceleration only from rear end - Ford Truck Enthusiasts Forums
Old 11-08-2010, 10:10 AM
v8only's Avatar
v8only v8only is offline
v8only is starting off with a positive reputation.
77 f150...open carrier 3.50 stock 31 spline 9" rear end.
I let off the gas and can hear a sort of grinding and/or clanking coming from the back.
On the frwy I let off the gas nearly all the way and it's got a disgustingly sick vibration coming from back there.
On visual inspection the u joints look ok and feel tight by hand movement...though I may just replace them anyhow.
Research tells me possible pinion problems with the rear.
Anyone else have an issue like this? Was it pinion problems in the rear? Should I just check the torque setting on the pinion nut, or is it more than likely that bearing going out? The rear feels very tight and is very quiet while accelerating and cruising,..it just flips out with the foot off the gas.
If it's the pinion bearing, anyone every replace one on their own? what is the level of difficulty? I'm skilled enough to rebuild mustang t5 transmissions and the sort, and have my own press in the garage, so I'm thinking maybe it's something I could have a go at.
No pinion shim on Richmond gear set? Ron94150 1987 - 1996 F150 & Larger F-Series Trucks 3 08-28-2015 09:35 PM
89 F250 rear pinion nut problem ... MontanaMan 1987 - 1996 F150 & Larger F-Series Trucks 7 08-05-2015 04:32 PM
How to find pinion angle? Thumper19 1987 - 1996 F150 & Larger F-Series Trucks 11 01-08-2012 04:01 PM
Occasional, repeatable binding from rear axle (I think) arootbeer Excursion - King of SUVs 8 08-25-2011 10:41 AM
Need Info On Rear End Replacement timsexcursion Excursion - King of SUVs 28 05-02-2007 10:53 PM
Tags
150, deacceleration, decel, decelerating, deceleration, differential, end, f150, ford, mustang, noise, rear, truck, vibrating, vibration
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
