Can You Mix Mercon V with DexronIII/Mercon? - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 11-08-2010, 10:24 AM
tonyford tonyford is offline
tonyford is starting off with a positive reputation.
When you do a drain and fill of your CD4E transmission in older Escapes (2003 is what have), there is still about 6 quarts of fluid left in the tranny. If the transmission has the older Mercon fluid in it, can you mix this with the newer Mercon V? Or, does the transmission have to be completely drained and refilled with the required amount of the newer Mercon V. I think the CD4E trans flluid capacity is 10 Qts., not sure though.
From what I have heard, Mercon V is thinner in viscosity than the old Mercon, just wondering if this will cause a problem since the transmission is used to the heavier weighted Mercon.
Old 11-08-2010, 09:46 PM
Seems like the experts are stumped on this one!
Old 11-08-2010, 11:55 PM
wptski wptski is offline
wptski is starting off with a positive reputation.
Is that correct? A 10 quart capacity and only 4 quarts drains out??
Old 11-09-2010, 07:59 AM
Quote:
Actually it's 10.1 quarts. When you drain from the "pan" only about 4 quarts come out, the rest of the fluid is in the torque converter and other internal parts of the transmission;
Here is a capacity chart for the Escape:
CAPACITIES:
Engine, with filter..........5.5 quarts [1]
Cooling System, Initial Fill..........10.6 quarts
Automatic Transmission, CD4E Initial Fill..........4 quarts
Automatic Transmission, Total Fill
4 speed CD4E..........10.1 quarts
Manual Transmission, 4WD..........4.7 pints
Manual Transmission, 2WD..........5.8 pints
Differential, Rear..........3 pints [2]
Transfer Case, PTO: 4WD Only..........0.9 pints
Of course there are other ways to drain out your transmission completly besides just draining out the 4 quarts. Some people will disconnect the cooler line going to the radiator, start the engine and add new fluid until you see the new fluid being pumped out. You will use about 12 qts. of fluid doing this.
I used the 3 times fill and drain method which will give you about 85 to 90% new fluid, but then every 15K miles drop only the 4 qts and refill. After about 3 times doing this, your fluid will be just about new. It's the process of progressive dilution. OR, just bring your vehicle to a reputable mechanic or service station or even Ford and have them do a complete drain and refill with new fluid.
Old 11-09-2010, 03:33 PM
Rancha9's Avatar
Rancha9 Rancha9 is offline
Rancha9 is starting off with a positive reputation.
MERCON and MERCON V are now fully compatible. Still always a good idea to get as much of the old stuff out, as it is with any fluid.
Old 11-09-2010, 07:51 PM
skibender skibender is offline
skibender is starting off with a positive reputation.
Quote:
I've heard that too. There's a TSB out there that states Mercon V is backwards compatible. But I haven't tested that theory yet. I'm still using the Mercon but plan on converting in the future.
Old 11-26-2010, 06:01 PM
Quote:
It's to risky unless you do like Rancha9 says, drain ALL the old Mercon/DexronIII out of the trans first. I doubt that mixing synthetic fluid with non synthetic fluid is a good idea.
Unless maybe you do the 3x's fill and drain, that might be okay, but still too risky especially on a vehicle like I have with 123000 on the odometer. The seals and internal parts are used to non synthetic Mercon fluid, changing this could cause problems.
Old 11-30-2010, 10:12 AM
martin_csr martin_csr is offline
martin_csr is starting off with a positive reputation.
For doing the fluid change... From another forum:
Search the internet for: Prowler's fluid change or Prowlers patented fluid change or Prowler's 7-6-3 or 5-5-5... something like that. It's an alternative way to change out the automatic transmission fluid by draining some, adding some, draining some, adding some, etc etc. You might get more search results if you preface your search w site:escape-central.com .
I don't recall the specifics, but I believe a helper is needed to keep topping off the fluid.
Old 11-30-2010, 12:21 PM
yes prowler is or was on EscapeCentral forum for many years, may still be on there. Basically it's simple and I been preaching this on this forum also.
Is Valvoline MaxLife ATF okay for 2003 Ford Escape V6? diyster Escape & Escape Hybrid 12 06-01-2016 10:54 PM
Mercon V vs. Mercon III AmmoDawg 1997-2006 Expedition & Navigator 2 01-08-2013 10:26 AM
Mixing Mercon LV and Mercon UaVaj 1999 to 2016 Super Duty 3 01-09-2011 07:04 PM
Mercon V=Mercon+LubegardSynergol? Can I mix them? lpk Oil & Lubrication 1 07-02-2008 09:20 PM
OK to mix different specs and brands of ATF? dharget Oil & Lubrication 4 06-24-2008 10:13 AM
Tags
2004, aode, at, bad, escape, fluid, ford, mecron, mercon, mix, mixing, navigator, place, transmision, v
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
