Battery light on dash off then on then off! Help - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 11-08-2010, 12:05 AM
dougbrown's Avatar
dougbrown dougbrown is offline
dougbrown has a very good reputation on FTE.dougbrown has a very good reputation on FTE.dougbrown has a very good reputation on FTE.
So I have a 96 F250, 136,030.6 miles on it, XL. I just did a oil change today that how I know it so well. I was having a problem with my battery light coming on the off a few months ago. I couldn't figure the problem out then, checked the altonter, batteries, cables. When I load test the batterys they where low. So I knew replacing them was soon but at the time money was not there. I replace them about 1.5 months ago when they quit on me. That stoped my battery light on dash problem. It when away after that! So I just figured it was batterys. Well today it was back on and now on when the truck is running. I know the start is going bad and cranks slow. Battery load test good! Figured the old batterys killed the starter. So I picked up a new one and it going in tomorrow along with a new start relay. Old one looks stock and for 22 bucks It can get a new one. I tryed to test the altonator to see how many volts it putting out but my voltage meter meet the fan blades before I could test it.
What could be causing the light to come on? Anything I should check while working on it? Any help would be great! I will get a new volt meter tomorrow. Also would that throw a code the code reader at work will pick up?
Old 11-08-2010, 08:36 AM
tbone heller's Avatar
tbone heller tbone heller is offline
tbone heller is starting off with a positive reputation.
Sounds like the alternator has a bad diode in it. Replace the alternator.
Old 11-08-2010, 09:38 AM
Cuda_jim's Avatar
Cuda_jim Cuda_jim is offline
Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.
Check the connector on the top of the alternator. The socket and pins are known to get loose. The wires almost always get flattened from laying on them while working in the engine bay.
Old 11-08-2010, 10:51 AM
ccarrier's Avatar
ccarrier ccarrier is offline
ccarrier has a good reputation on FTE.ccarrier has a good reputation on FTE.
There is a rubber hose that lays across the plugs on the ALT that causes this problem. Bend the metal loop bracket it's in back so it doesnt lay on it. The hose vibrates the plugs and causes the light. Well it did on mine anyway
Old 11-08-2010, 03:17 PM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is offline
Brown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud of
Check the main wire on the back of the alternator. The ring connector on my broke a few months ago and needed to be replaced. It was still charge when it was touching but it was barely held on by the little rubber boot.
Old 11-08-2010, 11:17 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Mine is starting the flashing battery light again as it has twice in the past. Both times I replaced the alternator and it fixed it. Now I need another one, Advance Auto is going to get tired of me getting a free replacement all the time. When I pull my camper I use a invertor to run two small refrigerators while driving down the road. My alternator really gets a work out and that is the reason they keep wearing out. If I replace the alternator again and the light keeps flashing well then, I might have one of the problems listed above.
Old 11-09-2010, 12:03 PM
dougbrown's Avatar
I dove around 50 miles yesturday and had no problem with it. Restarted fine, so i'm thinking it the problem described up top. Will check in a little.
Old 11-12-2010, 08:38 PM
MissIndependent's Avatar
MissIndependent MissIndependent is offline
MissIndependent is gaining momentum as a positive member of FTE.MissIndependent is gaining momentum as a positive member of FTE.
my truck has a similar battery light issue- it was intermittent for a while and now steady since the colder weather has set in (she likes it about as well as i do). new batteries, starter, and fender solenoid within the past several months, and alternator tests good. my boyfriend, a certified tech, was wondering about a voltage regulator??
i need top off power steering fluid and change a light bulb tomorrow, so i guess i'll add checking above-mentioned alternator items to the list lol...she starts strong and runs fine, so i'm not too worried, it's just annoying to see the light
Old 11-12-2010, 08:58 PM
blue66tang95f150 blue66tang95f150 is offline
blue66tang95f150 is starting off with a positive reputation.
Don't forget it could be the regulator. Mine was flashing intermittently for a while. I replaced the regulator and it has been fine ever since. I noticed when the light came on, the voltage gauge would jump slightly, I also noticed the batteries were boiling over.
Old 11-12-2010, 09:30 PM
Action4478 Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
The battery light is always the alternator , or the connector on top of it ...The regulator is in the alternator ....
Old 11-12-2010, 09:58 PM
Quote:
The regulator is on the back of the alternator and it can be replaced separately. It was making my light come ON on the dash when it would randomly quit working.
Old 11-12-2010, 10:03 PM
Quote:
Cool ...
How do you test which one is the problem ?
The light on , it is still the alternator , whether it is the alternator windings , or the regulator ....
That was my point ....
Old 11-13-2010, 12:27 AM
Mine is doing it as I said but I thought I would throw in that I put my scan guage on volts and I'm always showing 14 +or-??
Old 11-13-2010, 04:17 PM
Glenn ,did you check the connector?..
Old 11-13-2010, 08:23 PM
Ken_C's Avatar
Ken_C Ken_C is offline
Ken_C is gaining momentum as a positive member of FTE.
Voltage regulator wether internal or external to the alternator is replaceable. Its all in how much work do you want to do.
2001 expedition killing batteries! deputydog03 Expedition & Navigator 81 03-08-2016 10:20 PM
How to tell when you need new batteries... MC5C 6.0L Power Stroke Diesel 5 06-14-2015 08:05 AM
Passenger battery not charging. 99 7.3 bigbadbob17 1999 - 2003 7.3L Power Stroke Diesel 20 01-01-2015 11:23 PM
Starting problem sammatt1 Excursion - King of SUVs 11 03-24-2014 02:00 AM
2003 7.3.....Alternator problems rwtdct 1999 - 2003 7.3L Power Stroke Diesel 14 08-07-2012 09:05 PM
Tags
96, 97, altenator, batery, battery, coming, escape, f150, f250, ford, light, muskegon, on, powerstroke, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
