If Slip yoke splines not lined up as previous. problems?
Old 12-28-2010, 01:53 AM
rvx290's Avatar
rvx290
rvx290 is offline
My 05 SCab has the driveshaft clunk everytime I take off from a stop, I purchased a can of the telflon grease used to lubricate it & marked the front of the slip yoke to line up when I reinstalled, my mark rubbed off somehow and cant tell exactly where to line it up, if they dont line up, will I have a driveline vibration? Or can the splines on the slip yoke only line up in one spot as I noticed there is one spot where there is a gap in one spot with about 3 splines missing, (blind splines I believe they are called) is this to align it? Not sure what to do now that I have no way of knowing how the slip yoke was previously lined up to the male end coming out of the trans.
Old 12-28-2010, 02:32 PM
Twinsdad98's Avatar
Twinsdad98
Twinsdad98 is offline
You might, but the alignment is more critical at the rear axle. I would reinstall the d/s, mark it once installed. If you do have some vibration, re-index the d/s 180 degrees and re-evaluate. It'll be more trial and error, but I don't see you having any issues if it's not in the exact spot as before..
Old 12-28-2010, 04:32 PM
screwy's Avatar
screwy
screwy is offline
While I cant speak personally about the F-150, most, if not all, drive shafts will only line up one way.
Old 12-28-2010, 11:32 PM
JoshNHRA's Avatar
JoshNHRA
JoshNHRA is offline
If the yoke has numerous amount of splines, yes you will need to re-install the driveshaft the same way it came off. This is called phazing. The u-joint need to be in phase or else driveshaft will not rotate smoothly, giving you a vibration.
Old 01-02-2011, 03:49 PM
ryan70asu's Avatar
ryan70asu
ryan70asu is offline
Maybe I got lucky but I just aligned the bolt holes up to the rear end and moved the slip yoke a spline forward or back til it matched the best. No vibration. Doesn't seem to bind. Been driving it for 20k+ now.
woodsmoke
12-29-2016 06:12 AM
woodsmoke
12-28-2016 04:13 PM
Rusty_S
01-25-2016 07:05 PM
Rusty_S
09-15-2015 09:54 PM
ohmyf150
04-09-2014 08:12 AM
Quick Reply: If Slip yoke splines not lined up as previous. problems?
