66 F250 Brake Drum Specs and Shoe fitment - Ford Truck Enthusiasts Forums
Old 11-07-2010, 10:37 PM
Slowdog Slowdog is offline
Slowdog is starting off with a positive reputation.
Three questions concerning my 1966 F250 brakes:
1. When I measure the brake drums (across the inside diameter) I get 12 3/16 inches diameter and 2 inches deep.
Thus, I am pretty sure I am supposed to have the 12 1/8 X 2 inch shoes, but after a search I cannot find the maximum allowed interior drum diameter for 12 1/8 inch drums. Does anyone have those specs? Is 1/16 over too much? My primary concern is over-extending the wheel cylinders...
I know that these are the original drums but I do not know how many times they have been turned....The drums are in good shape and I do not think that I need to have them turned again (at least not this time and if I can get everything else repaired...I might do the disc brake conversion the next time that I need brakes).
2. I remember years ago that when we installed new shoes we would hit the shoe with a heavy rubber mallet to conform the shoe to the drum as needed. Doing so would help the shoe break in evenly. Is this practice still recommended and if so, what is the best procedure for doing so???
3. The local parts store wants about $125.00 for the two sets of 12 1/8 x 2 brake shoes. Have any of you had any luck ordering such parts online and if so, from whom? I noticed that MAC's wants about $80 plus shipping...
Thanks!!
Old 11-07-2010, 10:48 PM
jhooch's Avatar
jhooch jhooch is offline
jhooch is gaining momentum as a positive member of FTE.
"Machine to" spec is .060 over standard and "discard spec" is .090 over standard. We typically do not "arc" the shoes to the drums any more. Drums should always get a new surface when installing new linings to ensure maximum performance out of the brakes, whether ny machining (if there is enough material), or replacing.
Old 11-08-2010, 11:49 AM
Thank you jhooch!!
I am terrible at math, how does .090 translate to measured inches?? My drums appear to be 1/16 over the 12 1/8 original size....
One last question, if you do not mind....if the drums are close to the .090 mark, would that cause the wheel cylinders to over-expand even if the adjusters (manual on this truck) are properly adjusted?
When I pulled the drums the wheel cylinders were, in fact, over extended (and terribly corroded as this truck sat idle for about 15 years) so I am replacing them (and all lines and master) but if the drum is now too large will that cause the wheel cylinders to blow out again?? They may have blown out previously due to improper adjustment, I have no way of knowing...
Thanks again!!
Slowdog
Old 11-08-2010, 09:20 PM
OldHarley's Avatar
OldHarley OldHarley is offline
OldHarley has a good reputation on FTE.OldHarley has a good reputation on FTE.OldHarley has a good reputation on FTE.
.0625 = 1/16"
.09375 = 3/32"
Old 11-08-2010, 10:35 PM
Thanks!
We (the O'Reilly parts guy and myself) are still having trouble figuring out what brake shoe fits these 12 1/8 inch drums on this 66 F250.
The part number "33" shoes are listed in some parts books as 12 x 2 and some as 12 1/8 x2 ??? Can anyone give me the correct part number for my shoes? Maybe if someone can give me a current FORD part number I can have it cross-referenced. The fellow at my parts store argued that there was not a 12 1/8 x 2 shoe for this truck until I got him to look up the drums and there they were....12 1/8 x2, so he was stumped....
On RockAuto, the Bendix, Monroe, Wagner and Raybestos 12 1/8 x2 shoes show part numbers with the "33". Autozone, O'Reilly, Advance Auto all show the part number "33" as 12 x 2. NAPA only shows a 12 x 2 1/2 shoe.
Thanks!
Old 11-09-2010, 12:58 AM
jhooch's Avatar
33 is the correct shoe number for the front and the rear of this truck as long as nothing has been changed. They are 12 1/8 X 2.
Old 11-09-2010, 05:44 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
All 1953/65 F250's have 12 1/8" x 2" brake shoes as did some 1966/72 F250's.
12" x 2 1/2" brake shoes introduced in 1966, standard equipment on Camper Specials, optional on other models.
1953/72: Whatever the front brake shoe size is, the rear will be the same.
1968/72 F250 2WD's with optional front discs have 12" x 2 1/2" rear brake shoes, as do all 1973/79 F250's.
1973/75 F250 4WD's have 12 1/8" x 2" front shoes, 12" x 2 1/2" rear shoes.
Old 11-09-2010, 11:07 AM
Thanks for the part number and the good information.
I must assume that although the local parts store shows the "33" shoes as 12 x 2 they must actually be 12 1/8 x 2, unless their parts providers have the older 12 x 2 shoes labeled as part "33".
I noticed that National Parts Depot and Mac's have the 12 1/8 x 2 shoes listed as part number F-2001-10. Is that by chance a Ford number, or just internal stocking numbers?
Old 11-09-2010, 11:54 AM
It's not a Ford part number of any kind. The number is gibberish...made up, because these sources cannot use Ford part numbers:
About 15 years ago, FoMoCo notified all the the repro parts sellers that in order to use Ford part numbers in their catalogues and in ads, they had to pay a yearly license fee.
Ford also notified all the Ford obsolete parts dealers they had to pay a similar fee to use Ford in their business names.
Most, if not all the obsolete parts dealers dropped Ford from their name, and AFAIK, only Carpenter's catalogs have Ford part numbers.
C7TZ-2001-J (replaced C5TZ-2001-A & C6TZ-2001-K) .. 12 1/8" x 2" Brake Shoes / Front/Rear is the same / Obsolete.
Fits: 1965/75 F250. These are brand new, not relined (or in some cases rebonded) shoes that autoparts stores, repro parts sellers have.
When I typed post #7, I searched around, was only able to find two NOS sets from two different sources.
Old 11-09-2010, 09:23 PM
Thank you for the part number....perhaps it will help me find and verify that I get the right parts....
Old 11-09-2010, 09:52 PM
jhooch's Avatar
My Raybestos catalog shows 33APG as the part# for 12 1/8 X 2. Most aftermarket companies (Raybestos, Bendix, Wagner, etc.) will use some form of that number, the prefixes and suffixes will change. 316PG is the Raybestos number for 12 X 2 1/2. Raybestos book shows both available for 1966.
1966 F250 brake drums 1966 F-250 1961 - 1966 F-100 & Larger F-Series Trucks 3 11-08-2016 08:25 PM
55 F250 brake drum/shoe size issue? a1tiguy 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 05-12-2016 09:02 PM
source for brake shoes 1950F2 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 01-13-2013 08:45 PM
Please, Need Help on Rear Brakes for 88 F250 GregonVI 1987 - 1996 F150 & Larger F-Series Trucks 7 10-29-2012 10:13 PM
Brake Drum Nightmare rosesrfree4u 1987 - 1996 F150 & Larger F-Series Trucks 6 08-27-2011 12:43 PM
Tags
12, 12x2, 18, 332, 66, brake, drum, drums, f250, ford, garage, replacing, specc, specs, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
