Checking fluid level on 5 speed OD transmission - Ford Truck Enthusiasts Forums
Old 11-07-2010, 10:06 PM
iwals's Avatar
iwals iwals is offline
iwals is starting off with a positive reputation.
I need to check the transmission fluid level on my dad's 1992 F150. It has the 5 speed OD manual transmission that takes ATF, and a 300 c.i. 6 cylinder. I can't get under it on level ground to check the level at the fill plug--the running boards are in the way. I use ramps when I change the oil. These lift the front end about 8" or so. If I tried to check the transmission's fluid level with it on the ramps, how far off would I be? Would this be an acceptable way to check it? I don't have jack stands and don't have a good place to use them if I did.
Old 11-07-2010, 11:36 PM
91chevywt's Avatar
91chevywt 91chevywt is offline
91chevywt is gaining momentum as a positive member of FTE.
Quote:
The level shouldn't be that different lifted up, it seems like the fill plug is in the middle of the trans. You'll have to judge by eye how much the trans is tilted. It's not like you can put any more in besides what is at the fill plug..since it has to be on ramps to fill it. It shouldn't be off by any significant amount.
Old 11-08-2010, 07:42 AM
wickedklown83's Avatar
wickedklown83 wickedklown83 is offline
wickedklown83 is starting off with a positive reputation.
i agree with 91... its how i have to check my 5 speed ranger is on ramps.. and i havnt seen no ill effects of its fill level in 5 years
Old 11-08-2010, 10:20 AM
iwals's Avatar
Thanks guys, really appreciate it.
Old 11-08-2010, 10:31 AM
nstueve's Avatar
nstueve nstueve is offline
nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.
well technically you can pull the shifter and the top plate and pour the atf in from the top of the tranny untill it runs from the fill plug hole... I just did that on my ZF542. of course this was on a f150 with extra ground clearance but I would think you could fill the tranny without it on the ramps... depends on if you want to slide under the truck without a creeper to put the fill plug back in...
No Level Indicators HRTKD Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 20 06-27-2016 02:40 PM
1996 E350 5.8L E4OD No Forward/No Reverse Gears njoniec 1968-2013 Full Size Vans 5 11-05-2014 05:44 PM
1991 250 351 engine e40d transmission fluid help smitty403 1987 - 1996 F150 & Larger F-Series Trucks 3 12-08-2010 05:26 AM
2005 F150 XL Transmission no Shifting fteduran 2004 - 2008 F150 12 07-25-2010 04:59 PM
Checking Transmission fluid level jeansain Explorer, Sport Trac, Mountaineer & Aviator 8 10-21-2009 09:55 PM
Tags
1992, 30, 5spd, 94, check, f150, fluid, ford, level, overdrive, ranger, s15, speed, tranny, transmission, truck, zf542
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
