Whats it worth?
Whats it worth?
I wouldbe very leary of this auction. It states it is a SCJ block, but never offers a casting # or any other kind of proof. Doesn't list acctuall bore diameter just says .020" over. That may be true and he may have the pistons going with so it won't become a problem. I would ask alot of questions if you are going to bid. I wouldn't use those KB Hyperetic pistons. That is just me. i would use a good forged piston. The only ones I know of that keith Black makes for FE's are cast. Again that is just me.
Scotty
Scotty
Whats it worth?
I asked what compression ratio he thought would result from use with Ed AL heads, he said it would be about 10.4:1
Does that sound right? Is that pump gas friendly?
If so, I think something like this would be a nice compliment to my intake, carb, cam, all MSD ignition and exhaust.
Can you run a desktop of this setup?
Crower power beast cam- let me search for the SPECSs.
here they are:
Cam Specs,
Grind Lobe Center :292H/112D
Advertised Duration (Intake): 292, (Exhaust) : 302
Duration @ 0.50 in. (Intake) : 214, (Exhaust) :224
Gross Lift(1.76/1.76) (Intake): .521", (Exhaust): .547"
here they are:
Cam Specs,
Whats it worth?
Personally, I would ask straight up for the casting numbers. The date code is about right for the SCJ, but the compression seems a little low. Stock SCJs had 10.6:1. I could be wrong on this, but would'nt the .020 overbore increase the compression? I dont have all the numbers handy, but it think that is right. I would also ask for more pics. Other than that, if its genuine, $2500-$3000 is a more reasonable assumption for a rebuilt SCJ short block. I bought my rebuilt CJ in '95 for $2500. Add the counter weight and lemans rods, subtract the heads and you still come up around $2500.
Stryder
Stryder
Whats it worth?
Originally posted by gtex
Cam Specs,
Cam Specs,
EDIT: I just looked at crowers site. They went from having no spec cards on their site to having the best spec cards in the business. One drawback; when I enter your part number it comes up with a totally different cam. Might email them and let them know and at the same time aske them for the specs.
Whats it worth?
crower part number is 16903
all the specs I can find are here.
http://www.crower.com/misc/m_cat.shtml
I've got the spec card somewhere in the shop. Maybe I'll post it soon.
Whats it worth?
Here ya go. I found and scanned my Cam Spec card.
http://www.thedreyerfamily.com/69f250/camspecs.htm
Give me your ideas for a good 428 Short Block that would match my current intake, carb, cam, Ed AL or comparable CJ type heads.
I want enough torque to pull a big boat, but enough top end to impress the buddies.
By the way I don't speak "Camese". Does the spec card indiacte any special setup that I might not have done?
For those that don't know, I'm suffereing from a lack of tire spinning low-end grunt and an off-idle bog. I think it's in the carb. but need to rule out the cam setup. I'm also not sure what pistons were installed on the last rebuild, it may have pretty low compresson.
Whats it worth?
Here is the comparison. The dotted line is the cam put in at the .050 spec and the solid is the advertised spec. I figured in the following.
.030 over 390
Stock C8AE-H heads
750cfm 4bbl and dual plane intake.
Headers w/mufflers
The truth is probably somewhere in the middle. Kinda hard to say, that is why I don't particularly care for this cam. It lets off cylinder pressure early and moves the valve very slowly. This makes the engine sound meaner than a rattlesnake but it just doesn't have the bite.
.030 over 390
Stock C8AE-H heads
Headers w/mufflers
Whats it worth?
Scotty
