89 F150 Key off, truck tries to start - Ford Truck Enthusiasts Forums
Old 11-07-2010, 07:33 PM
East TX Tim East TX Tim is offline
East TX Tim is starting off with a positive reputation.
I'm rebuilding a 1989 F-150, 4.9L I6, 5 speed manual transmission.
We've recently got it back from the shop where they did some work on it (we swapped out fuel tanks and put in new pumps).
It was giving us trouble when trying to start and it took a lot of effort to turn the key and hold it down to start the motor. We finally got it kicked off then then we couldn't get the thing to turn off, even when turning the key off and out of the cylinder. We kept turning the key to run and then to off and it finally died.
I replaced the lock cylinder, but when I hooked up the battery (with the key in the off position), it tried to start so something is open somewhere.
I tried testing the start relay. I hooked up the negative cable to battery and used my volt meter to test from the negative post of the battery to the positive post of the relay and got no reading. So, that indicates to me that relay is closed like it is supposed to be.
What other tests can I do to isolate the problem?
Do you think the solenoid may be stuck open or short across somehow?
When we had started it earlier and released the key, the starter acted like it was still trying to turn over, but then it quit doing it.
How big of a pain is it to swap out the solenoid ?
Same question for the starter?
I realize that I'll have to jack it up and crawl under it. This thing is sitting out by the barn and not on a concrete floor so I like to have everything out there before I start so I don't have to keep crawling out from underneath it to get stuff.
Old 11-07-2010, 07:39 PM
dustybumpers's Avatar
dustybumpers dustybumpers is offline
Posting Legend
dustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputation
solenoid is bad. it is on the fender behind the battery. takes about 5 mins to change. but the real problem, that caused the solenoid to go bad, is that you have a bad ground. fresh paint, and grounds don't work. scrape some paint off the block where the ground bolts on, and put some dielectric grease on the bolt and cable to keep it from corroding
Old 11-07-2010, 09:47 PM
CWPottenger CWPottenger is offline
CWPottenger is gaining momentum as a positive member of FTE.
yep sounds like solenoid.
Old 11-11-2010, 01:28 AM
drjoe171 drjoe171 is offline
drjoe171 is starting off with a positive reputation.
+3 I had a girl run my truck across the field, shut it off, took the key out and handed it to dad. A few min later, we saw smoke coming out from under the hood. Solenoid on the fender well was stuck and smoked itself and the starter a real pretty blue steel color. glad it wasn't dark and parked in the barn, eh? Makes me want to disconnect the battery on these trucks every time I walk away from them
starter won't disengage Singing River Farm 1994.5 - 1997 7.3L Power Stroke Diesel 18 01-25-2014 04:51 PM
1984 F250 fuel pump problems????? deputydog03 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 53 11-05-2013 04:41 PM
retarded remote entry and alarm/wiring xc4jokestomper 1987 - 1996 F150 & Larger F-Series Trucks 2 09-27-2010 08:59 PM
starter solenoid wiring alexjp91 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 11-19-2007 11:49 PM
1988 Bronco Starter Solenoid Help Beasty-Fella 1978 - 1996 Big Bronco 7 11-11-2003 07:49 PM
Tags
1987, 2002, attempst, battery, connect, engine, f150, ford, key, position, start, starting, truck, trys, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
