Not charging, new alternator 86 f150 302 efi
It looks like someone has already had problems and hacked the harness, then taped over the mess.
Most times the replacement pigtail comes with high quality waterproof heat shrink butt connectors.
Soldering the connections is best, but you might want to slip some heatshrink tubing on first.
The white/blk wire should loop back over to the other plug as you say.
Shown here:
Shown here:
It should work as is and does not need the white wire to loop around.
Will post harness photos and more info in a few hours.
https://www.ford-trucks.com/forums/9...ml#post9300829
<O</O
When my last junk yard G2 ALT (1986 4.9 G2) was tested at the auto parts store, the bench test harness had the stator wire loop around to the VR, all 3 inputs to the VR where used during the bench testing. But all of the 86 G2 ALT harnesses I have seen only use 2 wires, the green wire which is normal on the “I” input to the VR is at the “S” input.
<O</O
The white wire, shown in the ImageShack photo link, has a connector on it to feed an electric choke as used on a 4.9 carbed engine. It looks like the 4.9 and the 5.0 share the same ALT harness, I would not have guess that they would.
<O</O
At this point if you have tested and found 12v at all the needed points I would just remove the ALT harness and unwrap the tape and give it a good look over. There are 2 splice points that could have failed.
<O</O
Will post some harness photos shortly.
<O</O
Jim
Same problem please help.
So was your problem fixed by linking the white wire around to the regulator linkage? I have the same issue with the same harness and I’m stumped as to why I won’t get charge. Just bought a plug online with three wires going to the VR and hoping this will solve the problem. I’m happy to switch the the 3g alternator later but for now just need to get my daily driver back up and running.
baverwolf
04-14-2011 05:55 PM
JTRace5275
08-14-2006 02:37 PM
f100beatertruck
01-17-2004 10:50 PM
