U-joint Replacement in IFS
Old 11-07-2010, 12:04 PM
zottyzot's Avatar
zottyzot
zottyzot is offline
Hey guys, I need some help asap!!
I'm replacing the U-joints behind the front wheels on my '96 f-250 4x4 w/ IFS.
I've got both half shafts out and now I realized that the inboard ujoint on the passenger side also needs replacement.
I cant figure out how to get the yolk seperated from the rear.
Where does that seperate? Does the shaft go into the rear?
Or does the ujoint yolk slie off somehow?
Old 11-07-2010, 01:11 PM
Lazy K's Avatar
Lazy K
Lazy K is offline
I take it this is a D50 you are working on. If so there are guys here who have been able to use a ball joint press to replace that joint with it in place.
To get the inboard shaft out you have to open up the differential housing and remove a "C" clip and then pull the shaft straight out.
Old 11-07-2010, 01:14 PM
zottyzot's Avatar
zottyzot
zottyzot is offline
Yes, it is a dana 50. I should have mentioned that.
Thanks for the info...not sure what to do now. I really dont want to open up the diff.
Old 11-07-2010, 01:17 PM
Lazy K's Avatar
Lazy K
Lazy K is offline
I know. There was a guy in the same dilema a few weeks ago and he reported back that he changed that joint using a ball joint press, so that might be worth a try.
Old 11-07-2010, 02:40 PM
skyfox10's Avatar
skyfox10
skyfox10 is offline
Old 11-07-2010, 06:32 PM
zottyzot's Avatar
zottyzot
zottyzot is offline
Thanks guys!
I didnt replace the middle joint...It didn't have any play in it but it was very stiff...I'll probably regret that later.
Anyhow the job is done. Thanks again for the replies.
choptop49ford
07-12-2016 12:03 AM
steve(ill)
1997 - 2003 F150
03-03-2016 04:29 PM
1984F2506.9
12-04-2014 11:32 PM
engine57a
1999 to 2016 Super Duty
08-20-2006 06:07 PM
Quick Reply: U-joint Replacement in IFS
