Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 11-07-2010, 02:22 PM
kupaa's Avatar
kupaa kupaa is offline
Garage is empty, add now
kupaa is gaining momentum as a positive member of FTE.
thinking about used atf as fuel
Where can i find a filter that can filter down to micron?
__________________
2002 SC SB 4X4,6637,STRAIGHT PIPE,COBALT GAUGES,ITP OBA,REGULATED RETURN,HPX,AIH DELETE,BUILT TRANS,BILLET SHAFT AND CONVERTER,DP TUNER F6 LIVE TUNED BY JODY, GTP38R,CASSERLY 200CC 80% HYBRIDS,TERMINATED,20X10 XD,ATZ 35/12.50/20
468 HP 970 ft lbs
CHRIS
  #2 (permalink)
Old 11-07-2010, 02:45 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
you can get oil-type filters down to 2 micron, but I think you have to use sock type filters to go finer.
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #3 (permalink)
Old 11-07-2010, 02:54 PM
binuya's Avatar
binuya binuya is offline
binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.
Quote:
Here's a popular place for fuel/filtration needs: Fuel Filters, Industrial Filters & Biodiesel Filters | Cim-Tek, Goldenrod, Petro Clear, Bio-Tek
It's where I picked up my final filtration cartridge for my fueling cart. It's a huge (5"diameter x 11" long) 2 micron unit. I have passed over 1000 gallons of my biodiesel through it and it's showing no signs of slowing down yet.
Click the image to open in full size.
__________________
2001 F250 7.3 CC SB 4x4 Lariat
S&B Intake, MBRP 4" Turbo Back, HPX, AIH Delete, Hutch and Harpoon,
Isspro EV2's, Bilsteins, Warn Premium Hubs, Firestone Bags with Airlift onboard, Fumoto,
Homebrew American Biodiesel (B100 whenever I can)
1995 Mercedes Benz E300D, 2004 Mercedes ML350
  #4 (permalink)
Old 11-07-2010, 10:16 PM
kupaa's Avatar
Thanks guys.
__________________
468 HP 970 ft lbs
CHRIS
  #5 (permalink)
Old 11-07-2010, 11:10 PM
kupaa's Avatar
do you think this filter will work with used atf
Cim-Tek Bio-Tek Microglass Particulate Filter (Part Number 70230, Model Number 260BMG-02)
__________________
468 HP 970 ft lbs
CHRIS
Tags
73, 97, atf, automatic, buy, diesael, diesel, engine, f250, filter, filtration, fluid, ford, fuel, kupaa, transmission, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
