51 f1 300 6
51 f1 300 6
Has any one put a 300 six into f1 51 . I really like the flathead but as you know to really build a nice one many dinarooow.Plus I want to do something not the norm like the v8.I would like a dependable driver with a
little go go.. t5 with a 8 or 9 inch rear.Any thoughts
thanks George
thanks George
If you decide to go this route you probably will want to talk to the people over at the Ford Six forum: FORDSIX PERFORMANCE • Index page
This has come up before, but I think that the general consensus is that it's a little too long to fit an F-1 engine bay. That's not saying that it can't be done, but I'd plan on having to recess the firewall and run an electric fan. The big six is one of the best engines Ford ever built. I'd like to see it done.
Check out Col Flashman's gallery!
Ford Truck Enthusiasts User Gallery
Here's another one!
Pictures by overlandexpress_photos - Photobucket
The 300 was my second choice if I decided not to use the 292.
Another good reason to use a 300 is it gives you the option to put either a ZF-5 speed trans or an E4OD on the back. If you decided to use an E4OD, you could use an EFI 300 and the computer for the engine would also operate the transmission!!
Cheers,
Rick
I think the 460 would present more of a problem with width than length. The 300 is a long engine. Even with the radiator and support moved up to the six cylinder position I think that it will be awfully tight. SOMEBODY needs to give tthis a try and let us know how it goes!
Hey Guys, I got my mounts fabbed up and pictures taken. Since I'm a computer idiot I still can't post the pictures, they are in my gallery. Everything looks a little rough right now but body work and engine rebuild are to be done this winter.
I took measurements of the engine location:
Firewall inset to valve cover...2 1/2"
Firewall to front of waterpump...36"
Firewall to front edge of rad support..42 1/2"
Haven't checked but I might be able to use the 48 rad with
an electric fan.
Additional FYI my truck is sitting on a S10 chassis so I don't have the stock crossmember to deal with.
Brian
an electric fan.
Brian
Brian way cool look forward to your progress,I think it will be a cool ride. I am planning to get my flathead on the road and enjoy her until i decide about a doner motor. The flat head is great but I would like to have air and a little more go go without breaking the bank.300 I think fits the bill I did see another post that a f1 was running a 300 six it fit like a glove.Alot of people tell me to run a v8 well I am going to build what I like and something different,maybe after i do it wont be what I think it should be but what the heck its all about the build to me. Wow me me me Brian keep the posts coming.
