heater not working at idle - Ford Truck Enthusiasts Forums
Old 11-07-2010, 04:07 AM
jwheatley20's Avatar
jwheatley20 jwheatley20 is offline
jwheatley20 is starting off with a positive reputation.
When I idle, I notice my heater stops blowing hot air
I have te small grey tube plugged In too the box in the valve cover. What do I look for?
Old 11-07-2010, 05:03 AM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is offline
bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.
Thermostate might be stuck open as the radiator will cool down the system very rapidly at an idle if thermostate is wide open.
Old 11-07-2010, 06:47 AM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
As you have gauges, it should be quite apparent that your coolent temp is low if in fact your 'stat is open all the time. Does it take a long time to come up to operating temp?
Old 11-07-2010, 10:02 AM
No. It reaches operating temp in a normal fashion. Hmmm
Old 11-07-2010, 10:40 AM
dchamberlain's Avatar
dchamberlain dchamberlain is offline
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
At idle with the truck fully warmed up, are the heater hoses as warm as the upper radiator hose?
Also, does your truck have the vacuum controlled flow valve on the heater hose line, and if so, is it closing when you turn the heat to OFF, and opening when you turn it to any other setting?
Old 11-07-2010, 08:06 PM
Ill check on the hoses after work. What does this vacuum controlled Flo valve loom like? Ill check that also after work. I did my injectors in may. Last winter... my truck would blow hot air at idle. So I'm assuming its something I did. The only thing I mess with is I unplugged the AC compressor. And I noticed that little grey tube wasn't hooked up, so I hooked it up to the little black box above the valve cover.
Old 11-07-2010, 08:10 PM
I think all trucks after 2004 have the vacuum controlled valve. I don't have a picture or diagram of it. If your truck has it, the grey hose goes there. It will be pretty obvious, though. It'll be a valve on the heater hose with a nipple for a vacuum line.
I don't think the valve is your problem. The symptoms don't fit. But it's worth checking. Vacuum should close the valve when the heater control is in OFF and MAX A/C. In all other positions, there should be no vacuum on the grey hose and the valve's spring should open it.
Old 11-07-2010, 09:21 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
sometimes when there is little to no heat you may have a bad rad cap or a cracked degass bottle the system needs to be under a little pressure 15 lbs does it get warmer at high speed?
Old 11-08-2010, 05:27 AM
TheBestKindOfEX's Avatar
TheBestKindOfEX TheBestKindOfEX is offline
TheBestKindOfEX is gaining momentum as a positive member of FTE.TheBestKindOfEX is gaining momentum as a positive member of FTE.
Maybe the heater core is clogged enough to prevent heat at idle? I have read several posts about this problem. No heat at idle but heat returns when rev'd up some....
Post about heater core flush....
http://www.ford-trucks.com/forums/81...-too-well.html
Old 02-03-2012, 09:14 PM
the shop the shop is offline
the shop is starting off with a positive reputation.
Working on my wife's 2003 Excursion with a 6.0L Power Stroke Diesel
No heat, replaced the heater core,water pump, thermostat we have heat driving down the road but not at idle,Checked the blend door and it opens and closes ,the door is not cracked and the motor appears to be operating normally
The heater core is hot above an idle is so hot you can't touch it, but at a idle its cold. any ideas out there ,Thanks
Old 02-09-2012, 05:26 AM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Having same problem with an '04. Customer states it worked until HE installed new radiator.
Old 02-09-2012, 06:27 AM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
Is the belt slipping?
Check the pressure in the degas bottle
Old 02-09-2012, 08:02 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
Another heater not working at idle problem..........These are almost as common as EGR delete and tuner threads now--LOL.
Is the coolant level sufficiently high in the degas bottle and is the truck up to normal operating temperature?
Old 02-09-2012, 10:51 AM
critterf1's Avatar
Yup and Yup. Coolant level fine, water pump working, housing fine, heater core clear, new thermostat. What gives?
Old 02-09-2012, 10:56 AM
My typical response would be that the waterpump is not providing enough flow at idle which may be an impeller problem or a housing problem. I just have a problem believing that there are that many pump/housing problems. How's the ECT/EOT delta?
Heater not blowing hot yooper5.4 1999 to 2016 Super Duty 4 01-08-2014 12:03 PM
Just how important is a block heater? davbeisner 6.0L Power Stroke Diesel 15 10-22-2012 09:59 PM
97 2wd, 4.0 with all 3 O2 sensor heater codes? Spectramac Ranger & B-Series 20 04-23-2012 05:45 PM
Engine Block Heater?'s Mustangbru8 6.0L Power Stroke Diesel 41 11-18-2011 02:06 PM
idle surge when heater is on 87wreckerman 1987 - 1996 F150 & Larger F-Series Trucks 1 02-20-2009 08:48 AM
Tags
2003, 250, 60, blowing, diesel, edge, f150, ford, heater, hot, idle, powerstroke, stops, truck, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
