1986 F250 351 - heat riser $116 bucks at LMC trucks...? - Ford Truck Enthusiasts Forums
Old 11-06-2010, 08:53 PM
eriklane eriklane is offline
eriklane is starting off with a positive reputation.
Anyone know of a source for a cheaper one? Wow...
Old 11-06-2010, 10:02 PM
Onus's Avatar
Onus Onus is offline
Onus is gaining momentum as a positive member of FTE.
Junk yard? Used auto parts place as we have here in ct.
Old 11-06-2010, 10:28 PM
GLR's Avatar
GLR GLR is offline
GLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputation
I bought one for my 86 F250 with 351 at "Cole Muffler" for around $40. Have you checked with Rock auto?
Old 11-06-2010, 10:39 PM
Heat riser-made of gold?
$146 at Rock auto...OUCH.
Old 11-06-2010, 11:44 PM
nolan62's Avatar
nolan62 nolan62 is offline
nolan62 is starting off with a positive reputation.
Also check Craig's List for someone parting out an F150.
Old 11-07-2010, 06:21 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
E4TZ9A427A .. Heat Riser Valve / Obsolete
Last MSRP: $131.87 // Last dealer net cost: $59.34.
Eight Ford Dealers have one each.
Since the part is obsolete, the dealers can no longer return it to Ford for credit, so are STUCK with it.
This means you may be able to bargain the price down, if you don't like what's quoted.
If interested, I'll list the sources (closest to MI = Franklin IN), but...
E4TZ9A427A was later replaced by E4TZ9A427AA / It's also obsolete
You may not want this part number because its last MSRP was: $244.38 - dealer net cost was: $109.00.
If interested, I'll list some of the sources, as over 60 are available.
Old 11-07-2010, 07:13 AM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
Good time to look at headers!
Old 11-07-2010, 10:25 AM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Quote:
I don't know what type of valve this is(vacuum, mechanical) but if it's stuck open and doesn't leak, you could leave it alone. It's purpose is to make the engine warm up quicker. So if it doesn't work, the engine may hesitate and be a little bit more "finicky" when cold.
Old 11-07-2010, 11:16 AM
GLR's Avatar
GLR GLR is offline
Vacuum operated. Just checked autozone, Everco Pt no. 126 $92.29. I'm going to check with local muffler place tomorrow to see if they have any and cost.
wheels 1973 - 1979 F-100 & Larger F-Series Trucks 7 04-13-2004 01:08 AM
is this common 1987 - 1996 F150 & Larger F-Series Trucks 3 11-12-2002 02:38 AM
Wheelbase 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-14-2002 10:06 AM
Overheating 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-11-2001 11:13 PM
Tags
116, 351, 83, 86, e4tz9a427a, e4tz9a427aa, f150, f250, ford, heat, lmc, riser, risers, trucks, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
