Oil pan heater? - Ford Truck Enthusiasts Forums
Oil pan heater?
Old 11-06-2010, 06:36 PM
97Handshaker's Avatar
97Handshaker 97Handshaker is offline
97Handshaker is starting off with a positive reputation.
Oil pan heater?
hey guys, i was thinking about getting a oil pan heater for my truck for better starts in the morning. does anyone have any experience with them? i was debating between the wolverine model 9 or model 16. or getting the Kat 150W.
i want to leave it plugged in overnight, about 6-8 hours, would the 125 or 150 watt work for that long of period?
would the 250w wolverine burn the oil if it was left on that long?
thanks
Old 11-06-2010, 08:17 PM
Ron W.'s Avatar
Ron W. Ron W. is offline
Ron W. is starting off with a positive reputation.
Lived in Minnesota for 17 years, think block heater.
Old 11-07-2010, 07:30 PM
i was going to get a block heater at first, but it doesnt heat up the oil at all and it could leak or come out.
Old 11-07-2010, 08:24 PM
Ron W.'s Avatar
Quote:
I've got a 97 with a 5.4 at almost 167k miles, it's never leaked let alone fall out.
Old 11-07-2010, 08:42 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
We have some oil pan heaters, they don't work worth a crap. We have block heaters on all kinds of equipment and vehicles and I've never seen one leak, they also only need to be plugged in a few hours even in extreme cold. The longer any of them are plugged in the greater the fire danger, never excited about leaving stuff plugged in overnite.
Old 11-07-2010, 10:53 PM
djm1951 djm1951 is offline
djm1951 is starting off with a positive reputation.
Being born and raised in Minnesota in the 60s when it was a lot colder. We used block heaters so we could plug them in at night. We also had an oil heater that was a replacement dip stick and plugged that in and never had any problems. Ran the plug thru the grill. I hope that this helps.
Oil pan heater Watcher58 Excursion - King of SUVs 15 11-10-2016 09:20 AM
Advice on operating a 7.3 at -60*F 90pioneer 1999 - 2003 7.3L Power Stroke Diesel 9 08-08-2014 03:55 PM
Setting up transmission, oil pan, an battery heaters - Tugly get in here!! 90pioneer 1999 - 2003 7.3L Power Stroke Diesel 12 04-29-2013 09:15 AM
Oil and Transmission Pan Heaters 90pioneer 1999 - 2003 7.3L Power Stroke Diesel 7 03-13-2013 02:46 PM
First long trip with the Ole 99 F-350 gret ride but ex-wolverine 1999 - 2003 7.3L Power Stroke Diesel 44 05-31-2007 12:17 AM
Tags
150, 1999, 2010, diesel, explorer, f150, f350, ford, forum, heater, heaters, oil, pan, timer, truck, watt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
