Titan Tank Installation - VIDEO - Page 6 - Ford Truck Enthusiasts Forums
  #76
Old 08-15-2011, 01:23 PM
porthole's Avatar
porthole porthole is offline
porthole has a great reputation on FTE.porthole has a great reputation on FTE.porthole has a great reputation on FTE.porthole has a great reputation on FTE.porthole has a great reputation on FTE.
My 65 is in the garage. Hopefully when I get back from my current camp trip I will have "precisely" little fuel left in the tank to prepare for a Wednesday changeover.
Haven't looked yet, but when I did the tank on my GMC I removed the drive shaft, that made it a whole easier.
Also have not looked at eh venting yet. On the GMC the factory tank had a single 5/8" line. The replacement Titan used two 1/2" hoses (one at each end) "T'd" to the filler pipe.
Venting while filling was always an issue. I would fill to within 10 gallons of the fuel used and then run the pump on the slow speed.
  #77
Old 08-18-2011, 03:46 PM
porthole's Avatar
Tank is in, fairly easy. Hardest part was getting a DRW high enough to work.
I didn't care for the way the front tank support (not the strap) allowed the bolt to contact the tank. So I slipped a 2x4 inch piece of plastic between the bolt head and tank.
Now the hard part - go and fill up.
  #78
Old 08-18-2011, 05:52 PM
EpicCowlick's Avatar
EpicCowlick EpicCowlick is online now
EpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant future
Quote:
I wondered about that as well and decided to just watch it. I took a pic of my tank-on-bolt. Looks like zero wear.
  #79
Old 08-18-2011, 09:52 PM
porthole's Avatar
Little bit of rust there already, guess the powder coating is a little light in the loafers.
So, I put 8-9 gallons in, ran it for awhile, went to a sunoco with the lowest price (gas buddy phone ap), added 45.5 gallons cause that's all the cash I had (CC/debit down), down the neighborhood station fi another 13. 67 gallons, not bad. Figure the extra was the last fill up, I'm guessing he thought 12+ was light, so he kept squeezing it in.
  #80
Old 08-30-2011, 09:04 AM
porthole's Avatar
The two tanks, side by side.
I did not have to modify the transfer case skid plate as mentioned in the instructions.
  #81
Old 08-30-2011, 09:56 AM
That tank is a beast! I would be funny to sit the 26 gallon tank next to it.
  #82
Old 08-30-2011, 10:24 AM
porthole's Avatar
It would, the "small" one in this pic is about a third larger then yours.
  #83
Old 08-29-2012, 12:21 AM
Firekite's Avatar
Firekite Firekite is offline
Shining Adonis
Firekite has a great reputation on FTE.Firekite has a great reputation on FTE.Firekite has a great reputation on FTE.Firekite has a great reputation on FTE.Firekite has a great reputation on FTE.
Excellent video and tech info, thanks!
So I realize my FX4 skid is going away. The Titan skid is an additional purchase? Worth it? Is it something I can add later or need to order with the tank?
Also, did anyone ever figure out whether the dealership can change the DTE calculations to take into account the full 51 gallons? Or is it limited to stock short and long bed size tanks?
  #84
Old 08-29-2012, 03:17 PM
rob92761's Avatar
rob92761 rob92761 is offline
rob92761 is starting off with a positive reputation.
yes than can change the tank size. you have to find the right dealer my dealer charged me $28.00
  #85
Old 08-29-2012, 09:50 PM
Firekite's Avatar
Shining Adonis
Got it, thanks
Found it in the other thread, the procedure for the dealer's techs:
1) Ensure IDS is at least version 72.xx - current version is 72.04 (in May 2011)
2) Click on the toolbox icon at top left of main screen
3) Select 'Module Programming' - click checkmark icon
4) Select 'Programmable Parameters'
5) Select 'Fuel" - click checkmark icon
6) Select 'Front Fuel Tank - (IC) = xx' on bottom of parameter list
7) Select 50 (or whatever size you need) on right side of screen and click checkmark icon. Follow the remaining on-screen instructions.
  #86
Old 01-07-2013, 08:44 PM
ftodaro ftodaro is offline
ftodaro is starting off with a positive reputation.
Got it, thanks
Ok I am a new guy as you can see my first post. I have a 2012 F350 and desperately need to get a bigger tank installed. Before I started reading the forums I just went to my Ford Dealer and asked about installing an aftermarket tank. they looked at me like i was from Mars.
My concern is getting my computer programed. I assume that the list above is all i would need to educate my dealer. I was wondering how well the re program works, so the MTE is pretty accurate and does it impact the computers calculations of your MPG/
Thanks
Frank.
  #87
Old 01-16-2013, 04:57 PM
Firekite's Avatar
Shining Adonis
I finally got the 50 gallon Titan tank installed in mid December, and now I finally got my butt over to the Ford dealership this morning to reflash my computer. I emailed my service adviser those steps. I'm pretty sure they would've been lost without it, but I know that with those steps in front of them they were able to get it done.
  #88
Old 01-17-2013, 05:13 AM
rgreentmcs rgreentmcs is offline
rgreentmcs is starting off with a positive reputation.
Thanks
Frank.
Once the dealer reflashed my system it seems to be pretty accurate as far as the MTE and the MPG works just as before. IMO most dealers don't see many fuel tank changes but if you go to Titans and/or Transfer Flows websites they list installers in your area.
  #89
Old 11-30-2015, 03:29 PM
pmichael pmichael is offline
pmichael is starting off with a positive reputation.
Epic - Did you have to reset anything on the gauges to get it to register with 50 gallons?
  #90
Old 11-30-2015, 04:14 PM
Quote:
There is nothing the owner can do without a visit to the dealer or a re-programmer. The tank volume is a parameter in the ECM that can be changed but you have to have the right tools to do it. Once done, the MTE values will be correct.
Titan tank question Lawrencew 6.7L Power Stroke Diesel 5 03-22-2016 08:21 PM
Titan Tank Venting ftodaro 6.7L Power Stroke Diesel 22 02-10-2016 11:39 PM
Titan 50 gallon tank skid plate... optional? BCM 6.7L Power Stroke Diesel 6 01-03-2016 05:46 PM
F250 6.7 dsl Titan 50 gal tank Greynomad 1999 to 2016 Super Duty 1 12-28-2015 10:41 PM
50 Gallon Titan Tank m-chan68 6.7L Power Stroke Diesel 11 11-23-2015 05:44 PM
Tags
2011, 50, diesel, engine, f150, f250, ford, gallon, platinum, rc, tank, tanks, titan, ultima, white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
